Here is a link to some motors i got from Ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3836131634
Could someone tell me how to wire these in bipolar series to my 3 axis xylotex board?
thanks
ljoe
thanks
ljoe
Pin 6 = A
Pin 1 = A#
Pin 8 = B
Pin 3 = B#
Connect pins 2 & 5 together
Connect Pins 4 & 7 together
Here's a diagram to print an use when wiring your motors. Unipolar and Bipolar parallel are also in my gallery. Just change the colors to match the cable you use.
Bipolar series diagram;
Also, FYI;
Bipolar Parallel diagram
Unipolar diagram
Pre wired cables, PMax motor connectors, wire, etc are are also available online at
Firey Electronics
Best of luck to you!
J
thanks guys.
i didnt know i had to connect pins 2 and 5 together and 4 and 7 together.
I got them to spin ok.
thanks for your help.
