When tapping blind holes, I take the following precautions:
1. Grind the point off the tap, if it has a male center point. This will allow more good thread to be cut to a greater depth.
2. Run the tapping cycle in air first to see how much overtravel the Z axis takes before reversal occurs. By comparing the coordinate display with the commanded depth, one can see perhaps .05" overrun and allow for this.
I've run hundreds of holes with a #0-80 tap in 303 SS this way, at 1000 rpm. Drilled depth .265" and tapped depth .195" I peck tap this hole because I use ordinary plug taps, as spiral flutes are not available in this size, and they are too weak anyway. I always tap these with a dedicated tapping fluid, not just coolant.
I've used #2-56 spiral flutes ( and larger) and they do tend to chip a tooth far sooner than an ordinary tap. So frequent inspection of the tap with a magnifier is a good plan.
