586,077 active members*
3,591 visitors online*
Results 1 to 6 of 6
    Mar 2008
    36
    rebuilting a ballscrew
    Hello I need some info on ballbearings, Im looking for info on harness and type of material to source for rebuilding my ballscrews, the od of the ball bearings
    are 0.124. I like to know where to source them, what material type is best suited for this, should i over size the ballbearing .002 ? i was looking on ebay
    but didnt find any vendors that had that size?
    please advice
    Mar 2008
    36
    has anyone rebuilt or take apart a ballscrew nut
    Mar 2005
    187
    hi markus,
    I have purchased very specific sized balls from http://www.precisionballs.com/
    They also have a great article on rebuilding a ballscrews here: http://www.precisionballs.com/Ball_Screw_Repair.html
    Best Regards,
    Andy
    Mar 2008
    36
    bal-tec
    what size and type of balls did u get and how many balls for the price? di you get... let us know how you made out changing them
    Aug 2005
    132
    Hi markus_detroy,
    I replaced the balls in works cnc machine. Basicly preloaded them.
    Too much play in the kit when we bought it.
    I bought 3 sets of each size above what size the ones were in the nut.
    I ended up using the largest set and it still wasn't enough.
    If it is and old nut then probably get the next size up and maybe one after that to be sure. They are cheap enough.
    Click on a size from the link below and it will show all the different sizes around that size.
    The trick I used for putting them in was first count how many balls came out.
    Use that amount of the new to put back in. Maybe one less.
    Screw the nut onto the middle of the screw. Make sure it has a bit of oil on it.
    Drop the balls in only one of the filler holes. Rotate the nut slightly when no more could go in until you can add more.
    I also used a small bit of plastic to push them together after every 5 or so balls. Keep going until they come out the other end.
    You should only have enough then to fit a few in the filler tube.
    Use grease to hold them in. while you pop it back in.
    If you have too many when they start coming back out. keep putting them back in and push them up to each other very 5 or so balls.
    Well thats how I did it anyway.
    Oh man I just wasted my time writting this.
    They explain it here.
    http://www.rockfordballscrew.com/man...ice-Manual.pdf
    Oh and the link for the balls
    http://stores.ebay.com/ToolSupply_Ba...QQftidZ2QQtZkm
    Cheers
    Rodney
    Mar 2005
    187
    hi markus,
    I was repairing a linear bearing, and not a ballscrew. So I can't advise on what size to get.
    At http://www.precisionballs.com/Ball_Screw_Repair.html they have suggestions on what to do size wise when oversizing the balls.
    Have them send you an assortment of ball sizes, just a couple of balls in each size so you can test fit.
    Over at www.industrialhobbies.com they have ballscrew disassembly / reassembly instructions for a single ballnut, have a look.
    http://industrialhobbies.com/howto/p...le_ballnut.htm
    Andy
  1. Ballscrew
    By andersbrun in forum Linear and Rotary Motion
    Last Post: 01-05-2008, 07:23 PM
  2. Ballscrew ? Nut?
    By pointcloud in forum Mechanical Calculations/Engineering Design
    Last Post: 04-26-2007, 06:46 PM
  3. Replies: 10
    Last Post: 01-16-2007, 06:27 PM
  4. Ballscrew diy??
    By lolailando in forum Linear and Rotary Motion
    Last Post: 11-23-2005, 06:51 PM
  5. My new ballscrew
    By lt paul in forum Uncategorised MetalWorking Machines
    Last Post: 07-24-2004, 05:35 PM
