586,379 active members*
3,447 visitors online*
    Sep 2004
    48
    Adding 4th axis
    Just wondering what is needed to add a 4th axis to a KM5P mill.
    Is the axis pcb available?
    Does the machine need a different software?
    Do some positioners work better, or are easier to use, with the Hurco than others?
    Your experiences, comments are appreciated.
    Thanks in advance,
    bgmnn
    Jan 2008
    124
    Need more info as to what you wish to do. Do you need the 4th axis to contour with the XYZ, or is it strictly for positioning? And what resolution do yuo need???
    Sep 2004
    48
    Just wondering what the machine was originally capable of.
    The machine is of early 1990 manufacture.
    The x,y,z axis are discriminated to .0000 on the crt.
    Is interface with the machine controller needed only for contouring?
  1. Adding a slaved X axis
    By t140nick in forum Mach Software (ArtSoft software)
    Last Post: 02-05-2009, 09:05 AM
  2. adding 4th axis with ez board
    By me2cyclops in forum Hobbycnc (Products)
    Last Post: 03-28-2008, 04:29 AM
  3. adding a 4th axis?
    By airbrush in forum Uncategorised WoodWorking Machines
    Last Post: 10-12-2007, 11:00 PM
  4. adding 4th&5th axis
    By cnc prog in forum Daewoo/Doosan
    Last Post: 09-25-2006, 10:26 AM
  5. Adding A 4th Axis
    By helix77 in forum EdgeCam
    Last Post: 04-13-2006, 08:36 PM
