586,350 active members*
3,186 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Newbie going nuttie
    Apr 2006
    19
    Newbie going nuttie
    This is probably something really simple!
    I bought a used 2000 VMC 3016, just getting it running.
    If I put a mag base indicator on the mill table with the indicator against a tool holder in the spindle.
    Then jog the X axis until the indicator shows 0.100" movement,
    the DRO on the machine says X has only moved 0.084"
    This was really driving me nutty until I figured out what was happening!
    Is there a scaling factor somewhere in the machine setup that I have to set?
    Robert Paisley
    Apr 2006
    19
    figured it out
    My machine has metric ballscrews and the inch ballscrew parameter was set.
    Easy problems are better than the alternative!
    Robert
    Apr 2008
    6
    possible backlash
    I've never seen as much as .016 difference between DRO and TIR due to backlash but it's easy enough to check and fix if thats your problem. I can't imagine that being your problem however on a machine as new as that unless it's been run REAL hard. I ran a 1996 model that had to have the thrust bearings replaced cuz the backlash couldn't be adjusted out of it. Just a thought.
  1. help for newbie
    By willheg in forum DIY CNC Router Table Machines
    Last Post: 03-09-2008, 07:11 AM
  2. newbie c.n.c.er
    By Kmanco in forum Torchmate
    Last Post: 02-11-2008, 05:28 PM
  3. newbie here
    By morgan320i in forum MetalWork Discussion
    Last Post: 12-04-2007, 05:14 AM
  4. Newbie in need of help
    By Erlock in forum Mastercam
    Last Post: 06-06-2007, 02:12 PM
  5. Newbie Needs help!
    By gmarquez04 in forum CNC Machine Related Electronics
    Last Post: 10-27-2004, 01:05 AM
