586,075 active members*
4,054 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > hyundia HiT 18s spindle intermitent start problems
    Apr 2006
    9
    Lightbulb hyundia HiT 18s spindle intermitent start problems
    Hi guys;
    In need of assistance
    Our Hyundai HiT-18 cnc lathe is having spindle start issues
    press the start and after a random time 5-45 minutes the spindle will start; it will run the program; do all operations to completion until it hits a spindle stop command, It stops, the next part is loaded in the spindle;
    Then another random amount of wait time before it re-starts.
    When you input the start command, the console shows it is active, the direction light and speed indicator are active, no faults displayed
    The motor drive board shows a ready state; after a random amount of time the drive board will make an audible vibrating sound (like a relay buzzing) once the relay clicks the drive board shows a run state; the spindle starts and runs; the program runs, machine functions normally until the next programmed stop
    Siemen’s 840 controller:
    The fault appears to be in the in Simodrive 611 motor control board {6SN1121-OBA12-0AA0}
    An help appreciated
    Doug
    Apr 2009
    1262
    Re: hyundia HiT 18s spindle intermitent start problems
    I think you hit the nail on the head. I believe that on your drive board that there is a small black relay about .5 by 1" that is sticking. It may be different depending on the vintage - some looked like ice cubes, but if you replace the relay you should remedy the problem.
    Best regards,
    Apr 2006
    9
    Smile Re: hyundia HiT 18s spindle intermitent start problems
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    Hi
    This board has 7 small relays in a row. Any idea which relay it is; or should I replace them all.
    They appear to be standard Tyco relays rebranded
    Did attempt to attach a board image
    Cheers
    Attachment 330274
    Apr 2009
    1262
    I can't see from the image, but it appears that there may be a label by each relay on the circuit board. I think that you should be able to "fire" the relay by applying voltage to the coil to determine which one is sticking without having to de-solder the relay. They should either click right away or not if it is the defective one. I'm not sure the operating voltage of the coil...does it say on the top of the relay or can you check? I'd hate to see you fry it by applying the wrong voltage...
    Best regards,
    you may also want to look for any discoloration of the relay or board (like excessive heat) to determine which one.
  1. Replies: 43
    Last Post: 11-07-2017, 04:53 AM
  2. Spindle Start Problems
    By clembrant in forum Mach Software (ArtSoft software)
    Last Post: 09-13-2015, 04:21 PM
  3. Hyundia Kia SKT28LM question
    By dynoman in forum Hyundai Kia
    Last Post: 01-09-2013, 11:29 AM
  4. Boss 5 Intermitent not responding
    By timprebleco in forum Bridgeport / Hardinge Mills
    Last Post: 03-11-2010, 04:06 PM
  5. Hyundia Himac V-100 Rs232 setup
    By cjels in forum Hyundai Kia
    Last Post: 02-03-2009, 11:44 AM
