586,055 active members*
4,277 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > Roland engraver/mill scripts for linux
    May 2008
    21
    I've developed some useful scripts (with some help from linuxquestions.org) to allow the hpgl based Roland engraver and milling machines. The ones I use are old but they use the same control set CAMM/GL or a close version or hpgl. The scripts have pop up screens to allow for enraver selection and speed settings. They work pretty darn good for me anyway in conjuction with coreldraw (wine),Inkscape and the roland 3d software that runs great in wine I can do pretty much anything I want.
    Here is a quick web site I did to help anyone get it installed I know the site stinks I'm no web designer and it shows!
    www.securetech-ns.ca
    This can easily be used for any hpgl device and roland's vinyl cutters also. Very little editing would be needed.
    Drop me a note if anyone finds it useful or improves on the interface by adding more options.
    I always engrave at the same depth so "z" depth are not a big factor to me.
    gary
    May 2008
    21
    HPGL Major Update
    The scripts are gone and replaced with a full GUI that supports multi-pass color coded jobs with a lot of new features. Both for roland rml1 and standard HPGL.
    get it at www.securetech-ns.ca/securetech.html
  1. Linux error code on CNC Mill
    By utahnorton in forum Centroid CNC Control Products
    Last Post: 07-28-2007, 07:36 PM
  2. Learning on the Sherline/linux/emc mill
    By sodle in forum LinuxCNC (formerly EMC2)
    Last Post: 04-12-2007, 05:00 PM
  3. Scripts
    By tjones in forum Tutorials
    Last Post: 01-25-2006, 07:06 PM
  4. Portable Engraver/Micro Mill?
    By NEATman in forum DIY CNC Router Table Machines
    Last Post: 07-15-2005, 10:33 PM
  5. vb scripts
    By HuFlungDung in forum Mastercam
    Last Post: 07-08-2003, 05:53 PM
