586,070 active members*
3,607 visitors online*
Results 1 to 13 of 13
    Apr 2008
    9
    ATC Alarm on Fanuc Controller
    During a tool change (1st tool dropped, indexed, 2nd tool engaged in spindle) I got this alarm and a buzzer went off in the PLC box.
    1024 ATC Cycle Error
    1005 ATC not ready
    The tool is locked in the spindle, but the tool changer did not move back.
    I believe I remember this happening before and we had to jog the tool changer back and forth to get it in the right spot again.
    Where do I start?
    Fanuc Series O-M running Supermax Rebel Mill w/ 20 tool changer.
    2932
    Up on top of the ATC is a motor that drives the cam. Take the cover box off, and you should see a "bail" (looks like a paint can handle, maybe?). Lift the bail to release the ATC brake, and you should be able to spin the fan to move the arm back to it's home position. Don't forget to apply the brake again after you're done.
    Apr 2008
    9
    which motor?
    I looked at the smaller motor directly on the tool changer and found nothing under the cover.
    There is a larger motor that moves the changer forward and back. Is it this one?
    If I remember correctly there is a switch in the control box where I can shuttle the changer back and forth manually (to and from spindle).
    Is the changer in the wrong fore/aft position, or is it rotationally wrong? I don't under stand why it stopped.
    Could it simply be chips/debris on a postion sensor?
    2932
    My bad. It appears as if you have an "umbrella" style tool changer as opposed to a dual-arm changer. I hadn't seen that style on a Rebel. Sorry for the wild goose chase.
    Have you tried calling YCI in California? 562-906-6118
    Oct 2004
    8
    cant get my toolchanger arm to return back, i looked inside my supermax max 1 and there is no bail and spinning the motor did nothing... hope someone can help me thru this one...
    Jun 2008
    1511
    snocat,
    Is this the same issue that you are having with the question you posted over at the machinetoolhelp forum? I responded over there as well.
    Stevo
    Oct 2004
    8
    YEP SAME THING....
    Jun 2008
    1511
    Well I can repost my response here or you can look over at the other post and see my response.
    Stevo
    Oct 2004
    8
    on my machine I ended up actuating the solenoid in the main power cabinet.
    got thru the error finally now i need to get my toolchange macro to read past the tool call in the program if its the same tool in the spindle.
    Jun 2008
    1511
    There is a few ways that you can do that. If the MTB used a system variable to track the tool in the spindle then you can use it in the macro. If they did not then you can set a common variable up to do the same thing. I cut the program that I posted for you in the other forum.
    Now if the MTB does not have a system variable we are going to use variable #500. Make sure that your machine does not use this variable for anything. If it does select another variable to use. Just make sure that it is 500 or above because these are the permanent common variables so they hold their value even if the power is turned off. First manually set #500 to what the current tool is in the spindle thru MDI mode.
    O9020(TOOL CHANGE PROGRAM)
    IF[#500EQ#4120]GOTO1—(checks to see if current tool is set to tool being called jumps to N1 if it is the same tool)
    #3=#4003—(sets #3 equal to modal G90 or G91)
    G40G80—(tool dia cancel & canned cycle cancel)
    G91G28Z0M9—(tool change position in Z & coolant off)
    M19--(tool orientation)
    G28Y0M5—(tool change position in Y & spindle stop)
    T#4120—(calls modal T)
    M6—(tool call of modal T value)
    G#3—(reinstates previous G90 or G91)
    #500=#4120—(sets #500 to the tool that was just input into the spindle)N1
    M99--(sup program end)
    This should work for you if you have macroB programming in the control.
    Stevo
    Aug 2011
    Can anyone help me on a DMV 3016 DAEWOO Mill my tool change arm will not go back I have a 2080 ATC interlock alarm
    Nov 2007
    352
    Jerry you need to post it as a full topic either in Fanuc or Daewoo/Doosan
    What State is the machine in
    E-Stopped
    Has it been or can it be referenced yet ?
    Do you have any manuals and what model of Control is it ?
    Jan 2013
    I am having problem ATC Alarm when z goes to +80.070. I am not able to tool change and rotate magazine. But i can do x y z to zero position.Machine model is Miyano TSV-25 Fanuc 0M. can anybody help me?
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. 972 NMI Alarm 18T controller
    By FanucIssues in forum Fanuc
    Last Post: 08-23-2018, 02:08 PM
  3. leadwell mcvo controller alarm
    By monaro mike in forum Fanuc
    Last Post: 03-21-2008, 12:38 PM
  4. fanuc 906 alarm
    By ezzhhh1 in forum Fanuc
    Last Post: 11-27-2007, 05:02 PM
  5. fanuc 5t alarm
    By markjb in forum Fanuc
    Last Post: 01-26-2007, 03:45 AM
