Hello all,
We have an LB-15 that intermittantly operates as though the single block switch is on although the switch is off. Have checked all of the obvious such as the switch itself, parameter 2 bit 0, and so on. Does anyone have a suggestion?
Hello all,
Check the slide hold button for a short. Has this happen once where the button got bumped while going for the cycle start button. We rarely use the slide hold and it apparently went bad. Replaced the switch and the problem went away.
check the operator door switch
Thanks for the information.
