586,754 active members*
7,556 visitors online*
Results 1 to 13 of 13
    Dec 2005
    35
    Angry need to find a replacement stepper motor urgently
    Today whilst V carving a photo to a max depth of 1 mm in pine on my shg - 609 my z axis stepper motor snapped its drive shaft at the lower bearing ( see attached photos) i need a new one asap and would like to know if anyone knows where in Brisbane i can go to get a new one and an approx price.
    all the info on the motor are as follows
    57hs2a76-404
    www.apexmotor.com
    NO.20071031
    considering i have only used this machine 5 times it has got me a bit peeved.
    any help would be much appreciated
    thanks
    Richard
    Attached Thumbnails Attached Thumbnails IMG_0856a.jpg   IMG_0857a.jpg   IMG_0858a.jpg   IMG_0859a.jpg
    Dec 2006
    878
    Is this machine from sh-cnc?
    Hi rocabig , I read a post where you were looking for sys-e. Is this the machine that you bought through him?
    If so, and the machine came from sh-cnc - why don`t you contact sh-cnc and find out if they can help you?
    Rocket.
    Aug 2005
    52
    Ocean controls may be able to suggest one of these as an alternative if you can find the exact specs from the apex site.
    http://www.oceancontrols.com.au/moto...per_motors.htm
    15362
    Hi roacbig
    I can't help you with the motor but I would change the coupling as it broke because
    of bad alignment the couping could not flex to take up the misalignment It can still be a solid design but with slots in & around it so it can flex or it will break again unless you can align it perfect.
    Mactec54
    24223
    I would agree that changing the coupling to flexible type would be advisable, solid coupling is probably the reason for the break.
    If you get the bellows type, I would suggest the stainless version over the aluminum type, which are really only suited for encoder loads.
    Al.
    Albert E.
    Dec 2005
    35
    Thankyou guys
    yes it is the one i got through sys-e and will never deal with him again he stuffed me around he told me it would take 14 to 30 days to deliver three months later i got it, i had to pay import and customs fees twice once to him and again to customs.
    have contacted sh-cnc and am awaiting them to reply
    need somthing this week as i have a job due on it on friday
    will checkout the mob in vic and a flex joint
    thanks again
    Richard
    May 2008
    Hello
    You might want to try lowcostcncretrofit.com, he might be able to help and is in QLD. Also try www.automationdirect.com.au.
    Erl
    Dec 2005
    35
    just had a search around and am getting apex to send me the specs on the motor
    was un able to find a flex coupling any ideas where to find one
    thanks again
    Richard
    May 2008
    G'day
    I looked around alot in Australia through standard suppliers and were very expensive. I got the ones for my mill at www.cncfusion.com for there X3 mill, they were the best price I could get. They are zero backlash type and only made for ally. Depending on the size of stepper, equals type of coupling torque rating, they have to match. Love-joy type work well and are cheap, but have backlash.
    Erl
    Aug 2005
    52
    Quote Originally Posted by rocabig View Post
    thanks again
    Richard
    believe it or not jaycar have cheap 1/4" flex couplings - I'm using them on a small lathe and they're OK-ish as far as backlash is concerned. They're not steel though so wouldn't stand up to huge loads like lovejoys. Might get your machine up and running while you look for better ones. Since the z-axis has the weight of the spindle on it shouldn't backlash be minimised since there's always some force on the coupling?
    As for Sys-e - I see he's stopped listing on trademe (a NZ auction site).
    Aug 2005
    52
    Aug 2005
    78
    Flexiable couplings
    Hello Richard
    Minature Bearings Australia - who are in Qld, have the flexiable couplings you need,
    http://www.minibearings.com.au/cgi-b...al&Step=3=post
    They aren't particularly cheap but using this style of coupler is cheaper than replacing the motor, at a pinch you could try oxyacletene ( sp? ) hose until you get a better coupler, I have seen it used on a homebuilt cnc router and it works fine, you may need to slow your cutting speed down, or not. Still a better option than a rigid coupler.
    Hope this helps.
    Ed
    Dec 2005
    35
    Thanks for the help guys
    have got a temporary replacement stepper till sh-cnc send out the new one covered under warranty
    went out yesterday to jaycar and got the spider coupler, had to machine out one end so it will fit the ball screw shaft but seems to work OK very minimal backlash
    thanks again
    Richard:wave:
  1. Possible replacement motor for an X3?
    By tauntdesigns in forum Benchtop Machines
    Last Post: 05-17-2008, 04:24 AM
  2. Help with finding a replacement stepper?
    By Brokengears in forum Stepper Motors / Drives
    Last Post: 11-05-2005, 07:57 PM
  3. SpectraLight Stepper replacement
    By Brokengears in forum MetalWork Discussion
    Last Post: 10-22-2005, 02:33 AM
  4. How to find out how much power (oz/in) do I need for stepper motor?
    By max7687 in forum Stepper Motors / Drives
    Last Post: 09-18-2005, 09:57 PM
  5. Need stepper motor replacement help
    By ProjectCNC in forum CNC Machine Related Electronics
    Last Post: 01-29-2004, 10:14 PM
