586,584 active members*
2,754 visitors online*
Page 1 of 2 12
Results 1 to 20 of 30
    Feb 2008
    19
    Machine freezing
    When running a programme the machine freezes on a particular tool, after reset, it runs, after pallet change it drills one hole then freezes again, NO alarms. I have tried changing the tool No etc.. no luck. Particular part of prog is same for tap other than G84 depth etc. Can anyone help?
    Thanks in advance.
    Tom
    2932
    What machine? What control? Please post "snippet" of the program where it freezes.
    Feb 2008
    19
    Thanks for speedy reply
    Daewoo, fanuc o-m control,
    T100
    M6 (TAPPING DRILL 1/4 BSP)
    #1 =54
    WHILE[#1 LE57 ]DO1 (No OF OFFSETS)
    G90 G0 G#1 X0. Y0. S1500 M3
    G43 Z100.H100 M8 T101
    G83 G98 Z-24.R5.Q14.5.F300
    G0 Z100.
    #1 =#1+1
    END1
    freezes when it reaches g55 x0y0
    2932
    Is this code part of a macro, or part of the main program? To be honest, I've never tried running DO loops in the main. Have you tried coding it long hand to see if the problem's with the macro language or something else?
    T100
    G90 G0 G54 X0. Y0. S1500 M3
    G55 X0. Y0.
    G56 X0. Y0.
    G57 X0. Y0.
    G0 Z100.
    Feb 2008
    19
    Part of a much larger prog, the rest run fine but for some reason this one doesnt, mostly programmed offine via copy and paste, so loop works but on this one???? just wondered if there was a parameter wrong as I dont have book cant check it out.
    Nov 2004
    19
    Are you dripfeeding the large program? I had this problem before and eventually found that when the screensaver or monitor power managment flicked on on the computer feeding the machine the machine would freeze with the spindle still running.Problem is that it is always in and around the same place making you think there is a problem with your program.Try running just the part causing the problem.
    Also could be sub routines as some contollers prefer long hand programs.
    Hope this may help,
    Cheers
    Nov 2006
    174
    Decimal point
    Look at your G83 block
    You have two points in your number for Q
    Feb 2008
    586
    And if that doesn't work after you fix that extra decimal point, try using #100 instead of #1
    Oct 2006
    15
    Quote Originally Posted by beege View Post
    I can agree with you beege. I try to stay away from 10 as well.
    LE ? Perhaps a "<>" could replace this?
    2932
    I don't believe "<>" is a valid Fanuc operator. Or... I could be mistaken.
    Mar 2004
    761
    "<>" = not equal to. "NE"
    Wayne Hill
    Mar 2008
    4
    Freezeing
    Is it possible that you need to cancle the G54 Modal command before the machine will pick up the G55?/
    2932
    WayneHill,
    I know what "<>" means, I just didn't know it was valid on a Fanuc. You learn something new every day.
    May 2007
    1003
    Quote Originally Posted by AS9100 View Post
    G54-G59 are work offsets. I know of no code to cancel one. Simply programming the desired work offset cancels the one currently in affect. At least it does on all the machines I program for.
    May 2007
    1003
    Isn't there a limit to how many times you can use #1 in a program? Meaning if your main program goes 7 subprograms deep, and you are using #1 in each subprogram to set different values, aren't you limited to something like 4 deep?
    Been teaching myself to program this way the past year so this is more a question on my part than a solution to the original poster's problem. I'm doubtful this is his problem as his G54 work offset will run.
    So far I have limited my use of #1-#26 to G65 Macro calls. Just personal preference, as I'm sure local variables can probably be used in many other types of programming methods.
    Feb 2008
    586
    I know #1 thru #26 are good for passing numbers from the G65 line, but I've always thought that #100-#149 (or #199, depending on options) were best used for those you didn't need to pass through the G65 call, like a calculation result. I don't think theres a limit on how many times #1 is used, but it shouldn't be changed once its initialized by the G65 call. Just have to remember that #100 - #149 get erased by a shutdown. Of course you already know #500-#549 don't.
    Nov 2006
    174
    G54 cancel
    @g-codeguy...
    G53 (Machine coordinates) cancels a work offset.
    But anyway, that's by-the-by.
    Feb 2008
    586
    Quote Originally Posted by ChattaMan View Post
    @g-codeguy...
    Not really, but sort of, like G01 cancels G02, or G91 cancels G90
    Or G01 cancels G00
    More like change modes, not cancel.
    G53 is just another coordinate system.
    Nov 2006
    174
    Yep, I'll buy that one ;-)
    Wow are you guys off base. Hello! You CANNOT have 2 decimal points like this next to the Q!!!!!----->G83 G98 Z-24.R5. Q14.5. F300<-------change this first before you do anything else.
Page 1 of 2 12
  1. madcam freezing
    By skankpile in forum MadCAM
    Last Post: 03-22-2008, 03:55 AM
  2. freezing stepper
    By Designsync in forum Stepper Motors / Drives
    Last Post: 01-01-2008, 01:10 AM
  3. freezing plate
    By ilan in forum MetalWork Discussion
    Last Post: 10-23-2007, 04:32 PM
  4. freezing plate
    Last Post: 10-23-2007, 09:27 AM
  5. freezing plate
    Last Post: 10-23-2007, 09:16 AM
