586,119 active members*
3,556 visitors online*
Thread: formula?
    Feb 2008
    formula?
    Does anyone know the formula for cutting a piece to fit the pocket for inlay like if you were using a 1/32 bit and it came to a point what formula would you use to make the piece fit the pocket if the pocket came to point ?
    JoptionPane
    You'll need to radius the corners 1/64". There's no formula. You'll also probably need to leave .001-.003 clearance. Trial and error will tell you what you need there.
    156
    Quote Originally Posted by JOptionPane View Post
    JoptionPane
    What you are asking is too vague. formulas can be written for just about any kind of geometery to be cut.
    Assuming(?) you want a slip(?) fit. Offset the geometery of the plug to be .001 to .002 smaller all around the periphery of the pocket. And for a point of some kind you will need to calculate the vector angle and offset the .001 to .002 90 degrees to it. There is not just one formula.
    Safety - Quality - Production.
  1. need a formula
    By gravy in forum MetalWork Discussion
    Last Post: 03-29-2008, 01:38 PM
  2. looking for a Formula
    By rusticr6 in forum Haas Mills
    Last Post: 10-18-2007, 04:23 PM
  3. Need a formula
    By Turk88 in forum Community Club House
    Last Post: 06-15-2006, 02:06 PM
  4. What is the Formula?
    By widgitmaster in forum Uncategorised MetalWorking Machines
    Last Post: 03-24-2006, 05:35 AM
  5. formula please!
    By turmite in forum CNC Machine Related Electronics
    Last Post: 11-22-2003, 08:45 PM
