586,108 active members*
3,100 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MODIFY JOIN LINES
Results 1 to 12 of 12
    Sep 2007
    92
    MODIFY JOIN LINES
    Can anyone please tell me where to find MCX "join lines function" it was called modify join when I used MC9, Also if that is too easy, I also cannot for the life of me figure out how to convert splines to arcs and lines which in MC9 was called, "modify / convert to arcs and lines" that seemed so easy. Thanks for any input you can give me, I am struggling to like MCX2.
    Jan 2008
    9
    Hi cnc Bob: mastercamox comes with a variety of pdf files located in (perhaps) C:\mcamx2\documentation\V92XFunctions.pdf this is a comparation between mastercamv9 vs mastercamX or you can try out join entities from the edit menu or to modify try analize entitie, regarding your other cuestion I'll keep looking also. I apologize if my gramer or speling is a little rustic (english is my second language)
    Sep 2007
    92
    Thanks for the tip, I found it and it works, I just never thought of looking in the "edit" pulldown I thought that was for file management. I have to open my mind
    Sep 2008
    10
    ok say i have a line then a radius and then a line. they are all connected but each is their own line segment. i try joining all them together to make one full line that i can select with the join enitities function, but no dice. it comes up with a error saying these enitities cannot be joined. am i using the wrong function or can you just not do that? thanks
    Apr 2003
    3578
    you can not use the option to join a line and a arc togeather.
    Cadcam
    Jul 2006
    297
    sometimes i use EDIT TRIM function to trim one entity to the other.
    hope this is what you were looking for.
    2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
    Jul 2006
    297
    then if you hold down the shift key while selecting the chain it will select all entities at once
    Apr 2003
    3578
    Now if you do the same think and click on the first part of lets say a partial chain , keep holding down the Shift and click the last in your partial. this will give you guess what a Partial chain.
    Cadcam
    Jul 2006
    297
    im confused.lol
    so even tho all the entities are selected it is still considered a partial chain?
    what effects of toolpathing or machining would occur between a chain or a partial chain?
    Apr 2003
    3578
    Please review this link for the option of Shift chain as preselection.There is sound.
    http://www.mastercam-cadcam.com/vide...hiftchain.html
    Cadcam
    Aug 2007
    339
    Select your Fillet comand put in a 0.0 amount and select the two geometries you want to join. That's it. They are joined with no fillet. Hope this helps ya.
    Apr 2003
    3578
    Boots interesting way of doing it. but there are true functions just for these call outs.
    please review another picture of the tools in mastercam X and higher.
    Cadcam
  1. Time to join the group.
    By stepinator in forum DIY CNC Router Table Machines
    Last Post: 04-26-2012, 10:17 PM
  2. How do I join these together?
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 03-17-2008, 05:02 AM
  3. What's the most rigid way to join 80/20?
    By digits in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 10-26-2007, 11:16 PM
  4. Invitation to join in.........
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 01-29-2005, 03:57 PM
