586,329 active members*
5,205 visitors online*
Results 1 to 19 of 19
    Mar 2007
    84
    Tool changer (lathe)
    Hi everyone! I have an old cnc lathe to rebuild. It has a turret that handle 6 tools. At the beginning I wanted to use EMC2, but then I change my mind because TCNC is more compatible with old system.
    Could someone explain me how exactly automatic toolchanging can be done in TCNC? Did TOOL TURRET INDEX send a number of pulses of a tool? For example: when instruction M06 T4 is executed, there is a 4 pulses on TOOL TURRET INDEX pin or what? Need a help here.
    Guntis
    Sep 2006
    607
    There is only one pulse from TCNC. You can set how long this pulse is going to be though.
    So if you want to change tool, you will either have to place the next tool to use on the upcomming slot, or write several M6 commands. I'm trying to place the next tool I'm using in the next slot. If thats not possible, I will just have to repeat the M6 command a couple times..
    I have been toying with the idea of making a separat tool changing computer (just a microcontroller with LCD display and a simple keypad) which keeps track of what tool is to be used next and so indexes to this tool. My tool changer is already controlled by a microcontroller, so adding a feature like this should not be too hard.
    Mar 2007
    84
    Mmm! Thanks The Blight! So that signal just means: change to the next tool. I thought about using of a PLC here. Logic for that toolchange is this: PC gives a signal to change to Tn (n is a tool number), from another pin there goes PLC handshake signal that tell PLC to switch on a motor, instrumental disc is moving. Position is controlled by six magnetic reed switches, when there is the right tool for example T6, switch with the same number gives a log.1. to PLC, PLC gives a signal to reverse motor to lock instrumental disc, then the shaft press a microswitch, again the logical.1. signal goes to PLC input, PLC send signal to pin "PLC handshake sense". Tool is changed, everything is ok, TCNC can execute next line of program. This would be ideal for this purpose.
    Sep 2006
    607
    Sounds good enough. I use stepper motors for my tool changer. The only problem with this system is that if one of the motors loose a couple steps, you can end up with a machine trying to take a cut that is not locked in place, or take a cut with the wrong tool.
    I was thinking about another method on how to tell the controller what tool you want to use. Connect another axis output where you can write the tool number. On the controller for the ATC, you can check this line for which tool to use next. The bad side of this would be that you can't use the T word. In my eyes that would be too messy. I like a clean code, so I'm just setting it up to use the next tool in line.
    Mar 2007
    84
    I got an idea. :idea: You said that Your tool changer use a stepper motor. I know that in TCNC there can be set an axis which use angular positions so called A, B, C axis). For example we have 4 tools. 4 tools = 360 degree. So the stepper motor should rotate every 90 degrees to change to another tool. Just write a simple code in the line and You got it! At this moment it seems to be a simplest solution for this. Sad, that I cant use it in my system.
    Sep 2006
    607
    I have set my changer up as a linear axis at the moment going from 1 to 4. I think I have set it as the Y axis (lathe), and if I type G00 Y1 it goes to tool pos. 1. First I have to release the locking pin, which is axis A. So G00 A1, G00 Y1, G00 A0 is a tool change. I just need to hook up the new microcontroller so that it takes care of the whole tool change with offsets for the locking pin and a home position sensor.
    How does your tool changer work? Got any pictures?
    Mar 2007
    84
    Hi! Sorry for my late answer.
    This one works exactly I explained in my previous post where I mentioned PLC- except is that there is used special electroautomatic control board instead of modern PLC. I found very interesting homepage where is explained how to build simple PIC based PLC : http://getok.net/plc2pic/index.php?next=index . Maybe it is worth to build one? Another idea is to change TCNC code in a way that TCNC gives in output a number of pulses equal to number of tool. T4 for example gives 4 pulses on some LPT pin. This would be more and more easier than it is now...
    Aaa-and here are some photos:
    Attached Thumbnails Attached Thumbnails toolchanger.JPG   toolholder.JPG   korpuss.JPG   tmotor.JPG
    Jul 2008
    199
    diy lathe turret and the macro to run it
    Quote Originally Posted by The Blight View Post
    hello blight,
    i really liked your idea of using the a axis and y axis for moving the locking pin and the stepper motor. But i am wondering that how did you manage the tool offsets and m6 command?
    any help will be appreciated as i am building a turret too( same as yours).
    regards,
    jasminder singh
    It is better to die for something than to live for nothing.
    Sep 2006
    607
    Looks like a nice project, and a beautiful cleanup so far.
    That PLC circuit looks simple enough, and it should work just fine if you can hook it up. Do you know how to program in turbo pascal? If you get around to do some changes in TCNC, please share. I tried to get into programming pascal, but I gave up shortly after.
    Mar 2007
    84
    Smile
    A good friend help me a lot in programming. Now we are trying to make TCNC multilingual (english, latvian and russian languages in one program, later maybe some other). If everything goes in a good way, then TCNC will became as a special OS for cnc machines. Of course I will share with the results. I must say many thanks to Dave Kowalczyk for this great program and his efforts to write it. It is really great and easy to use program.
    The Blight- can You show a pictures of Your toolchanger?
    Sep 2006
    607
    TCNC is really easy to use, and it has lots of functions. I think it's a great piece of software, and I don't think I will change. Dave has started working on it again it seems. I hope he fixes some of the bugs and adds a couple new features.
    The ATC is for my mini lathe (which I also have built myself), and it's for taking light cuts. I have taken 2mm cuts in brass, and it doesn't complain. I get some vibrations when using a 2mm parting tool, but it does work.
    May 2005
    925
    wow, very nice ATC, I would like to have something like it for my Syil C6, do you know where can I find ready made ATC like the one you built?
    Sep 2006
    607
    I think Enco have one, but I don't know how much it costs. There is lots of plans out there on how to make one. The problem is doing just that. I have heard some talk about using a rotary table to hold the tools. Might work if there is no slop in the system, or if you find a good locking system.
    Mar 2007
    84
    Ok-some more progress on this thing (highschool takes a lot of time... Ehh! ). After some thinking I ended up with this design which uses a M71 and M70 commands. All electronics contains a couple of relays and some simple logic IC (SN74xx series). When it came to replace a tool (M06 M71 Txx command) TCNC make defined LPT port output active which enables toolchanger logic. In next step we need to enter a tool number from keypad-it starts an asinchronous motor to move an instrumental disc. If position is the same with choosed tool, circuit reverses motor spining direction. When disc became fixed it push the end switch- it disable motor spining. Thats all folks! Tool is changed and we can push the button OK and lathe can continue work. You can see a concept of the circuit in attached picture (circuit is done in simulator so it is slightly simplified). I hope that I will make a PCB this week. Cant wait to see it working!
    Sep 2006
    607
    The M6 command also has an output that can be enabled (a single pulse that comes on whenever the M6 command is issued. It stays on for a fixed amount of time). The manual states that the M6 command sends out a number of pulses equal to the tool number, but this is not correct. It sends out one pulse no matter what. I'm using the M6 command for toolchange, and the M73 to check for PLC input (when the ATC is done, it will tell TCNC that it can continue with the program).
    Mar 2007
    84
    Offtopic: The Blight-I noticed that You have a very nice DIY cnc lathe. How about some video?
    Sep 2006
    607
    Hehe. I didn't have time to take a video of it today as I was configuring the offsets for the machine. I'm also rewriting some of the code for the ATC, so I will have to change the chip tomorrow. If I can remember to bring the camera, I will be sure to upload a video.
    Have you gotten your machine to work?
    Mar 2007
    84
    Not yet actually... There is still a lot of work to be done. This lathe is a project Im working on from time to time. Now I will got more spare time and I decided to do some really serious work on this project.
    Sep 2006
    607
    Well, I bought a license for tcnc, and reprogrammed the M06 command (and made several others for calibration), so I don't really use the axis commands any more. The M06 commands works kind of like the M10 command (I think thats the one) with a parallel 4 bit bus that tells the tool changer what tool to load. The rest is handled by a micro controller that controls the steppers in the tool changer. I have also set up a handshake line, and a start line. The 4-bit bus is also used for jogging and calibration.
    So everything is handled by the microcontroller, and the software is just telling it what to do.
    Oh, and if I could do it again, I would have made the turret differently with a better locking system
  1. Hoss 16 Tool Automatic Tool Changer
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-03-2011, 10:29 PM
  2. Lathe & Tool Changer Design (WIP)
    By Noodles87 in forum Vertical Mill, Lathe Project Log
    Last Post: 03-13-2008, 05:49 AM
  3. Intelitek 0400 Lathe and Tool Changer
    By Too_Many_Tools in forum Mini Lathe
    Last Post: 08-24-2007, 08:04 PM
  4. Replies: 1
    Last Post: 07-18-2006, 12:51 AM
  5. Any lathe tool changer plans around?
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 05-04-2005, 07:31 AM
