newbie question, :drowning:
what is difference between absolute and incremental G-code?
after .dxf to .txt need convert to absolute G-code or no need?
thanks
thanks
There is a world of difference: incremental programming means the control simply moves the machine to the next point relative to the present position. This can cause an accumulated error. It also makes starting in the middle of a program an impossibility.
Absolute programming reckons all movements relative to a datum or reference point on the part. Errors (due to rounding off) do not accumulate). Mid program starts are feasible if done carefully.
Good question, good reply, this is one that should be added to Graham's index.
Gary
Newbie's PoV on mid program starts!Originally Posted by HuFlungDung
Try to work out which direction the cutter is going to move on the restart and then jog manually to a safe position away from the workpiece before doing the restart!
This may save a rapid into the workpiece and the resulting destruction! (ask me how I know )
