we have a fellows paper shredder that had the gears stripped in it...it was a good shredder...but when i took it apart to see why it quit shredding...i saw some drive gear teeth broke off..thinking oh well ill have to get some gears...but i have looked around some for replacment gears,had very little luck..this was a while ago 4-6 months ago so today i decided to look at it again..the gear had a "C" clip on it but must have fell off and let the gear climb onto the other gear...and rip a few teath off..which in turn got caught in the other gear and made a mess out of it also (it must have been close to quiting time and they didnt wanna put the clip all the way onto the shaft to hold the gear together )......so i have two gears ruined...if i had the parts (cheap) i would just fix it...but another thought came across my head,how bout using it for a spindle motor?? it is an "ac" motor has 120v 60hz on it....seems to turn pretty fast...and could prolly be over driven with pully's to get even faster...i did notice it got some what hot...like maybe it was not intended to run for a very long time continuosly, it is a "graphite??" brushed motor ,...but it dont say the horse power,or anything but i could not stall it by simply pushing on the out put shaft with a stick....thinking if it had a fan on top...it would be cooler..lota work yeah..but thought id share it with yall as i couldnt find any threads with this particular type motor (a paper shredder) mentioned as the spindle motor (have to admit my search skills arent that good)...and thought yall might wanna look for some at yard sales for cnc use....on the side note has any of yall used one of these motors for your cnc...? did it run hot ,and still perform well for a long time?? or maybe even if some one could tell me a really good place to get replacement gears (cheap) to just fix it ?? i still think id rather use it for a spindle motor .....""no honey it cant be fixed,the gears is all torn up...guess ill 'HAVE TO' use it for my cnc router build"" think she will buy that story??
