Hi all,
I want to connect a hose to the oil drain plug on my car, and looking for the simplest, yet proper way to go about it. First, this is the part...
Rough dimensions... ~25-26mm thread major dia x 1.5mm pitch. Hex head = 17mm. Washer head diameter = ~33mm. The ID on the threaded side is 15mm, but I can perhaps drill it to 18mm since the wall is very thick.
Idea 1 was to drill/tap the head for 1/4" NPT and attach a barbed fitting, but the ID of a 1/4" barb fitting is very small, so the flow rate of thick cold oil will be slooooowwwwwww.
Idea 2 is to get some type of fitting to replace this plug, but I can't find anything with that same thread.
Idea 3 is to find a bolt with the same thread and modify it, but again I can't find a bolt with that thread.
Idea 4 is to completely machine a new part. I have a CNC mill and a manual lathe, but I haven't figured out how to thread with the lathe :nono: Perhaps I can single-point thread with the mill... hmmm.
Idea 5 (from someone else), is to cut off the head and weld a pipe nipple to it. I believe the part is made of steel (heavy and magnetic) with what looks like a zinc-chromate finish. I haven't worked with this before, but I should be able to grind off the finish and weld to it.
I'm leaning towards 4 or 5. If I can weld to this material easily, then it might be the way to go, but I wouldn't mind a nice small milling/lathing project to learn a bit more.
Any thoughts/opinions/advice?
Cheers,
-Neil.
