I'm considering this for my next purchase, i want some honest opinions from thoes that either experienced it first hand, or anyone who would like to just comment on the general specs. This is going to be machining aluminum motorcyle parts in average quantitys. Ranging from 2"x2" to 8"x10" in batches of 100 - 2000 peices.
It's made by Modern Tool, not sure where exactly.
MODERN Model MM-430 Mini Vertical Machining Center
Here's a link to the PDF.
http://www.moderntool.com/new%20pics...n%20MM-430.pdf
Here's a link to some pictures,
http://www.moderntool.com/new%20pics...Mini%20CNC.jpg
http://www.moderntool.com/new%20pics...%20control.jpg
http://www.moderntool.com/new%20pics...%20spindle.jpg
Price listed is $49,000 CAD. The 4th axis is another $21,000, which seems quite high to me?
Some input would be highly appriciated ..
Some specs below incase you can't view PDF.
Jer
Code:
C/W: Fagor 8040MC CNC Control
SPECIFICATIONS:
Table:
Table Size 35.43” X 16.14”
Distance Table to Floor 32.28”
Table Weight Capacity 770 lbs.
Table T Slots (4) .625” X 3.93” Centers
Travel:
X Axis 29.92”
Y Axis 16.93”
Z Axis 15.74” (Std.) 18.11” (Opt.)
Spindle:
Taper ISO 40
Spindle bearing I.D. 2.36”
Spindle Speed 8,000 RPM
Spindle center to guide way 18.89”
Spindle nose to table surface 4.01” – 22.12”
Ballscrew:
X Axis Dia. 1.259” X P8
Y Axis Dia. 1.259” X P8
Z Axis Dia. 1.259” X P8
Linear Guideways (Ball) X/Y/Z 1.377”
Modern MM-430 CNC Page 2
Motors:
Spindle 7.3/10 HP
X Axis 2.84 nm
Y Axis 2.84 nm
Z Axis 8.34 nm
Coolant pump ¼ HP
Automatic Tool Changer:
Pockets 16
Tool Taper BT#40 / CAT#40/DIN69871
Max tool weight 11.88 lbs
Max tool diameter 3.5” (using all pockets)
Performance:
Rapid traverse: 944 I.P.M.
Positioning accuracy +/- .00019”
Repeatability +/- .00019”
Dimension &Weight
10.5 ft x 9.5 ft x 8 ft
Basic Machine 7500LBS
Complete With:
Fagor 8040MC CNC Control, DNC Software, Coolant System, Work Lamp, Full Enclosure, 16 Tools A.T.C., CSA Electrics, Manuals and maintenance tools.
PRICE . . . . . . . .. . . . . . FOB CALGARY/ EDMONTON . . . . . $49,900.00 CDN.
Options
4th Axis Table………………………………………………………..$ 21,500. 00
