586,058 active members*
3,874 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mazak QT15 with T32-B control does not switch to automatic mode
    Jun 2008
    Exclamation Mazak QT15 with T32-B control does not switch to automatic mode
    I bought a used Mazak from the UK and shipped it to South Africa. The machine is set up, turret works, spindle works, home search is ok, programming and tool setting is OK but I can't swith to automatic mode. Where do I start looking?
    (nuts)
    Feb 2008
    25
    Hello.
    What happen when you try to switch to automatic?
    does the spindle start? does it do the toolchange?
    Be a bit more specific
    Vladimir
    Jan 2008
    65
    make sure that your doors are shut all the way. sometimes they wont go into auto if the doors are open
  1. Mazak QT15 Manuals
    By javajesus in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-15-2022, 07:37 PM
  2. Mazak QT15 533 programming error
    By Pziggy in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2014, 07:31 PM
  3. Mazak QT15 turret blocks
    Last Post: 02-10-2008, 01:31 AM
  4. Mazak QT15 Tapping Issue
    By Pziggy in forum MetalWork Discussion
    Last Post: 01-16-2008, 09:29 PM
  5. MODE SELECTOR SWITCH FOR 0i-T
    By CHANDRU in forum Fanuc
    Last Post: 10-21-2007, 04:46 PM
