586,076 active members*
4,037 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > bobcad v21 geometry won't select correctly
    May 2005
    64
    bob cad v21.5.3
    I have shallow arcs in the y/z plane, very nearly in the x/y plane.
    Bob cad won't seem to let me select them from the end I want.
    have you seen this, do you have a suggestion?
    May 2005
    64
    hmmph
    I closed and restarted bobcad, no change
    restarted the pc, no change
    removed a new pendrive with U3, no change
    out of desperation, I rotated the view slightly. Ahah!
    Went back to top view, everything normal.
  1. How to correctly chamfer a hole?
    By Darc in forum G-Code Programing
    Last Post: 06-03-2021, 09:10 AM
  2. DFX is not imported correctly...
    By ihkim in forum Uncategorised CAM Discussion
    Last Post: 01-07-2010, 06:57 PM
  3. new to bobcad 3d geometry not visable
    By djtoolz in forum BobCad-Cam
    Last Post: 02-11-2008, 04:07 PM
  4. Will Jog but not Move Correctly in G code
    By dafowfidy in forum Mach Software (ArtSoft software)
    Last Post: 03-30-2007, 04:27 AM
