586,096 active members*
3,813 visitors online*
Results 1 to 8 of 8
    Mar 2006
    153
    Back plot software
    Does anyone know of any software that will backplot a macro program?
    No matter how good you are, there is always someone better!!!
    Mar 2006
    153
    That software looks good but its overkill for what I need.
    322
    NCPlot does Macro B
    NCPlot does Macro B backplotting. They also have a freeware Macro B expression evaluator utility.
    http://www.ncplot.com/
    -James
    James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
    Quote Originally Posted by jemmyell View Post
    -James
    NCPlot does not verify all of the macro B expressions. Just some of them. Which basically makes it useless under most circumstances. Vericut is overkill? I guess your parts aren't that important then. Vericut is a tool. NCPlot is a toy. Tell you what download the trail version of NCPlot and see how well it works. When it fails post your code here and I will run it through Vericut and show you something that works.
    P.S. Vericut is an awesome program but you don't need all the modules (Machine Simulation, Opti Path, 5 axis, etc.) to do what you need. All you need is 3 axis simulation. ($7,000)
    Mar 2006
    153
    What I meant by overkill is that I already have tool path verification through my cam software. So the only thing I would be getting vericut for is the three or four macros that I need to write.
    chrisryn,
    You are wrong. Cam software simulation only checks the internal cutter location data NOT the actual G code that runs your machine. A huge differance there. Vericut catches critical mistakes and crashes that Cam systems DO NOT.
    765
    Quote Originally Posted by Mike Stevenson View Post
    Hi Mike,
    Which Macro B expressions are not supported by NCPlot? Useless under most circumstances? How about some examples.
    You are comparing $300 software to $7000 software. Which one do you think most people can afford? If the $300 will do what you need, why spend the extra dough?
    Scott
  1. NC Plot v2 Beta 5
    By MetLHead in forum NCPlot G-Code editor / backplotter
    Last Post: 09-14-2008, 10:20 PM
  2. Back plot time
    By impdesign in forum Mastercam
    Last Post: 11-19-2007, 03:00 PM
  3. NC PLOT Question?
    By TURNER in forum NCPlot G-Code editor / backplotter
    Last Post: 09-13-2005, 10:15 PM
  4. NC Plot Discussion
    By jonbanquer in forum NCPlot G-Code editor / backplotter
    Last Post: 07-24-2005, 01:22 AM
  5. Batch Plot??
    By cncadmin in forum Autodesk
    Last Post: 07-16-2003, 05:02 PM
