586,082 active members*
3,629 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Need Help Building Table for TM3 8'x20'
    Oct 2007
    25
    I am am looking for suggestions and maybe drawings to build a table for a TM3 of 8' by 20'.
    The table will cut with plasma and oxy and will have the plate marker accesory, so I think I would like to have a water bed underneath.
    Any ideas where to start?
    If you'd like frame dimensions on a TM3 8'x20' PM me your email address and I can send you a few PDF files. As far as a water table, there are a few decent designs floating around on these forums, I would recommend a seperate in-table tub that can be moved/removed if necessary.
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
    Oct 2007
    25
    Thanks!
    Mike,
    I sent you a PM with my personal email address.
    Regards,
    Salvador
    May 2008
    39
    mike,
    why do the plans call for 6x3x3/16 tubing instead of just using the 3x3 there and lenghting the legs to save a little bit of money? is there any structural issues?
    just wondering
    baker
  1. building xy table and servo tapping
    By jimc in forum Servo Drives
    Last Post: 02-25-2008, 04:58 AM
  2. need advise on building my own table or just buy one.
    By HMD in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-18-2007, 10:25 PM
  3. help in building a vacuum table
    By barth11496 in forum DIY CNC Router Table Machines
    Last Post: 09-21-2006, 03:22 PM
  4. Building Router Table
    By PROBUILDER in forum DIY CNC Router Table Machines
    Last Post: 04-11-2004, 07:58 PM
  5. Help? First attempt at building CNC table
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 04-22-2003, 07:16 PM
