586,216 active members*
3,181 visitors online*
IndustryArena Forum > CAD Software > Autodesk > points to lines/arcs
Results 1 to 8 of 8
    Oct 2005
    1145
    Does anyone know of a lisp or macro that can take set of points taken from around the outside of an object(probed points) and convert them to lines and arcs. It would be nice IF you could specify a tolerance of what is a straight line and what is an arc.
    Thanks (;-) TP
    Jan 2008
    24
    did you manage to get an answer to this? i need something of the same need to take a set of points that are in a group and make them into a spline or surface
    Nov 2005
    1468
    If you have the X and Y co-ordinates then it's easy peasy-
    Create a plain text file using WordPad or similar. Make sure it's got SCR as an extension.
    Cut and Paste the X and Y co-ordinates into the file- one set per line and X,Y separated by a comma.
    Make sure the first line of the SCR file says "PLINE" (without the quotes).
    So, an example file would look like this:
    PLINE
    10.9876,1.2345
    10.8765,1.3456
    10.7654,1.4567
    etc...
    Save it somewhere you'll remember.
    Boot up AutoCAD. Type in "SCRIPT" and select the file you just made- AutoCAD will import all the co-ordinates as a polyline. Ta Da!
    If you need them as individual lines then just EXPLODE the polyline.
    Hope this helps!
    I love deadlines- I like the whooshing sound they make as they fly by.
    Jan 2008
    24
    now will that same thing work if there X Y Z cords? and use a 3dpoly line? or can you only do a 2d version
    ill test it either way tho
    thanks for the info
    JM
    Nov 2005
    1468
    Not sure MPH..would be interesting to know though!
    As you can see from my Avatar, I'm only a simple 2 Dimensional engineer
    Yes, just use:
    3Dpoly
    x,y,z
    x,y,z
    etc......
    Oct 2005
    1145
    Gerry when you explode the Pline does it make full length lines and arcs or just lines from the many many points. The problem I was trying to overcome was to end up with thousands of small line segments. It drives the machines crazy and really slows them down.
    Thanks (;-) TP
    It breaks it at every vertex, so even if you have a straight segment composed of 5 sections, you'll get 5 lines when exploding. It's not smart enough to convert the 5 lines into 1.
  1. Points to Surfs
    By JDcam in forum Rhino 3D
    Last Post: 01-26-2009, 06:04 PM
  2. ramped arcs are linear points no g2
    By dertsap in forum Mastercam
    Last Post: 01-19-2008, 06:28 AM
  3. Creating a HATCH of points not lines
    By vmax549 in forum Autodesk
    Last Post: 12-13-2007, 06:21 PM
  4. Points on arcs
    By gguidi in forum Autodesk
    Last Post: 07-25-2006, 01:49 PM
  5. lines-arcs vs spline problem
    By metlcutr55 in forum Uncategorised CAM Discussion
    Last Post: 07-07-2006, 04:16 PM
