586,075 active members*
3,974 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > torchmate cad deleting image to leave path
Results 1 to 8 of 8
    Aug 2007
    20
    Hi
    When I delete the original image I get a message that it will lost the relationship. if I say OK then the cut path cannot be show again I think it has been deleted too. I have followed the instuction by turning off "show cut path" so only the original image shows but what ever I do it wont work.
    Info please
    Tack1000
    Feb 2008
    121
    Not sure about your problem, but was wondering if you like the software, was thinking of purchasing a copy.. Is it as good as it looks. Thanks
    Aug 2007
    20
    Hi
    I will let you know once have run a few jobs. t the moment program the plasma by hand.
    As far as the first question....sorted it. The "link to original " check box was ticked.
    Thanks any way.
    Feb 2008
    121
    Tack1000 what type of a table you have! Thks
    Aug 2007
    20
    Hi
    8 X 4 table with water bed, made the lot myself with torchmate auto head adjuster, motors and racks, all the rest home grown.
    Tack1000
    May 2008
    39
    do you go back and select the view tool path only afterward?
    baker
    Aug 2007
    20
    Hi
    Yes I did but I found the problem to be the group command was checked so when I deleted the original the whole thing was deleted as they were grouped.
    Thanks for asking
    Tack1000
    In the Torchmate CAD Version 7, under the Options menu, select Torchmate Setup, and then select Tool Path Preferences. There is an option that says "Group Tool Paths with Originals" that is checked. If you un-check that, the toolpath and original will no longer get grouped together when you create the toolpath.
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
  1. Leave the the Zone to search GOOGLE
    By widgitmaster in forum Polls
    Last Post: 09-10-2015, 07:38 AM
  2. Programming Mills To Leave Stock On When Profiling?
    By Eddie1962 in forum Haas Mills
    Last Post: 04-15-2008, 07:30 PM
  3. deleting line between points
    By BrassBuilder in forum Dolphin CAD/CAM
    Last Post: 03-04-2008, 02:54 AM
