586,036 active members*
3,819 visitors online*
    Jun 2008
    6
    Smile Draw TRUMPF TC5000R NC CODE IN AUTOCAD
    I write a add-in in AUTOCAD, it can convert the punch code to cad drawing, hope someone interest it!
    because the addin is limitied by the AUTOCAD version, so it can only used in AUTOCAD 2002 now, I would like to compile it in other version if you want it.
    Attached Files Attached Files
    Post
    Unless your writing the programs in CAM software I am not sure why you would need to do this. It may be of use for older punching machines that have hand written programs, however, the Trumpf TC5000R is not a machine that you would want to write the program by hand.
    Independent CNC Programmer
    www.ctcn.net/~3kings/
    My mission is to share CNC programming innovations for a lifetime.
    Jun 2008
    6
    Thank you for your reply.
    In fact I want to write a NC simulation software in the beginning. It can simulate NC code of PUNCH&CUTTING step by step and can save the reverse drawing to DXF file, send the NC code to machine. But I found I have no much time to finish it at once.
    so I write a AUTOCAD addin first to see how many people interest this kind of soft.
    I appreciate you suggestion. thank you!
    Jun 2008
    6
    it,s a exe file I made to simulate the NC code, it should be easy to use than the AUTOCAD addin, but it can't save the drawing to dxf at present
  1. Draw G-Code by Hand (Interested) ??
    By Switcher in forum Visual Basic
    Last Post: 08-14-2019, 12:54 PM
  2. G-code for Trumpf turret punch
    By Sparkman Stan in forum G-Code Programing
    Last Post: 02-27-2016, 06:29 AM
  3. Corel draw - autocad question laser!
    By Sandor_nl in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-26-2008, 03:24 PM
  4. AutoCaD to G-code/CAM
    By droddis in forum Autodesk
    Last Post: 01-25-2008, 03:47 PM
  5. AutoCAD R14 3d Model to G-code to CNC
    By Sanghera in forum Autodesk
    Last Post: 01-20-2005, 01:22 PM
