586,119 active members*
3,615 visitors online*
    Nov 2007
    9
    Small mill feed?
    Hi All, I'm running a bunch of small jobs in brass which require a lot of cutting with a 1/32" end mill. I'm having
    pretty good luck with these parameters, but I'm breaking end mills if I run any faster:
    0.03125" diameter 4-flute HSS mill 0.0625" long
    4500 RPM (max)
    30% of tool diameter cut depth
    Flood coolant
    0.000125" chip load
    2.5 IPM feed
    Does this seem slow? I hate to experiment and break tons of mills... How would you trade cut depth vs feed rate for a little mill like this?
    Thanks!
    -Bill
    Feb 2007
    1084
    Get a 2 flute EM and repost, will make life MUCH easier.
    Nov 2007
    9
    Thanks -- what's the thinking behind the 2-flute? I don't think I'm getting much clogging of the flutes with the brass, and the 4-flute end mill should be stronger and allow me to run twice as fast...
    Cheers,
    -Bill
    Feb 2007
    1084
    You can increase the feedrate because you'll have more room to eject chips. 4 flutes are stronger, made for harder materials where you cut a lighter chip load. A 2 flute HSS is perfect for what your doing.
    Good luck!
    MC
  1. help with speed and feed carbide end mill
    By alex 850 in forum Bridgeport / Hardinge Mills
    Last Post: 12-27-2007, 06:10 AM
  2. Home made cross slide power feed for small lathe
    By monte55 in forum Uncategorised MetalWorking Machines
    Last Post: 12-16-2007, 08:30 PM
  3. Feed and Speed for 3d profiling with small tools?
    By Loading in forum MetalWork Discussion
    Last Post: 11-03-2007, 10:41 AM
  4. Small end mills feed speeds for 1mm steel
    By paulr4 in forum DIY CNC Router Table Machines
    Last Post: 08-13-2006, 01:29 PM
  5. EMCO FB-2 Mill - need power feed?
    By brassman1 in forum Benchtop Machines
    Last Post: 11-04-2005, 06:18 PM
