586,626 active members*
2,629 visitors online*
Results 1 to 3 of 3
    Apr 2008
    82
    my first attempt
    i have started my first router build.
    got a lot of great info from this site and the net.
    it's main use will be for cut out lettering and engraving in mostly plastics and a bit of aluminium for my sign business.
    it will be made mostly from a heap of scrap alu. i got really cheap ( channel, flat, etc. ) probally not the best but it will do.
    cutting size is 700mm x 580mm x 100mm.
    all 3 axis have linear rails and nsk ball screws that i got cheap of ebay.
    the ball screws have a pitch of 20mm, but im gearing the x+y axis 2:1 and the z 4:1 with pulleys.
    i have a size 34 + 2 23 steppers running from quickstep drivers.
    not sure of what controller yet, prob. mach 3.
    i will start with a router first, but would like to modify a mini mill spindle as well.
    anyway here is a first pic of some progress.
    May 2006
    138
    Looks like a great start. Looking forward to seeing it cut!
    Apr 2008
    82
    bit more progress
    heres a couple of progress pics.
  1. first attempt
    By corrie in forum Musical Instrument Design and Construction
    Last Post: 01-06-2008, 03:22 AM
  2. My first attempt
    By Caprirs in forum Vectric
    Last Post: 08-28-2006, 08:27 AM
  3. A axis attempt
    By Konstantin in forum Uncategorised MetalWorking Machines
    Last Post: 07-26-2006, 11:36 PM
