586,121 active members*
3,586 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Wanted: Swiss-Type Star SV-32 Parameter
    May 2005
    109
    Fanuc 16iTB Swiss-type STAR MICRONICS SV-32 lathe lost all parameter. I would like to buy this parameter set. If you have the same model lathe, please PM me.
    May 2005
    109
    Hi everybody,
    I tried to run this machine.
    It have two FSSBs that connect to servo amplifiers. The first one connect to 2 amplifiers which drive 5 servo motors. The second connect to another 2 amplifiers which drive 3 axis servo motors and two servo motors act like spindle. All motors have absolute pulse coders.
    I set dogless zero return with absolute encoder. After ref. return only first 5 motors (on first FSSB) remember zero point, 3 others do not (on 2nd FSSB).
    Do I miss something?
    Jan 2006
    14
    can you tell me the machine serial number? Maybe i can help you with a parameter set for SV-32 with FS-16iTB control.
    May 2005
    109
    Quote Originally Posted by Armageddon View Post
    I don't know why you need serial number? But I'll get back to workshop to get it. If you can help me without serial number, email to [email protected]
    Thanks for your help.
    Jun 2010
    46
    Serial number requirement
    The reason he needs the serial numer is that there differant settings for differant serial numbers due to options and upgrades of Fanuc equipment.
    The problem will be the fanuc options parameters to suit your machine and the hardware.
    I am surprised that you do not have your original electrical manual as the parameters are usually attached the them.
  1. Not round pieces Swiss-Type Miyano Screw Machine
    By gakor in forum MetalWork Discussion
    Last Post: 02-18-2008, 03:30 PM
  2. Help with Star SR20RII (Please)
    By mrtedzr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-27-2007, 08:12 PM
  3. Star
    By TZ250 in forum Dolphin CAD/CAM
    Last Post: 08-27-2007, 01:09 PM
  4. Machinists Wanted - Swiss Preferred -KC, MO
    By kctechlink in forum Employment Opportunity
    Last Post: 12-20-2006, 07:08 PM
  5. Need Star in .dxf
    By rcazwillis in forum Uncategorised CAM Discussion
    Last Post: 12-29-2005, 12:16 PM
