586,409 active members*
3,007 visitors online*
Results 1 to 7 of 7
    May 2008
    15
    Pulling the pieces together
    I have been gathering parts. My electronics are starting to trickle in and I'm needing to know what cable I will need to connect the breakout board to the computer? The breakout board looks like a parallel port. Do I connect to the parallel port or serial port on the computer? Thanks for all the great info here!
    Feb 2007
    4553
    parallel port
    DB-25 Straight through cable
    Jeff...
    May 2008
    15
    Thanks for a quick reply
    I knew if I could ask the right question, someone here would give me the answer. Again many Thanks. I am now back to gathering parts!
    May 2008
    15
    Will Start Assembly This Weekend!
    I know it's probably considered cheating, but I ordered the kit from BuildYourCnc.com. I'm more interested in what I can do with the finished machine that spending the time building it from scratch. That being said, I will try to take some pictures of the kit and the build as I go so I can share with folks on this forum. Again thanks for the info and support I've already learned soo much from you guys.
    Steve
    May 2008
    15
    My Kit came in early last week
    Here's a couple of pics of what I received
    May 2008
    15
    Made some progress on assembley
    Few Pics of what I've been able to get done so far.
    Attached Thumbnails Attached Thumbnails IMG_0460.JPG   IMG_0461.JPG   IMG_0462.JPG   IMG_0463.JPG
    May 2008
    15
    Router is in the Mounts!
    Got the lead screws and anti backlash nuts installed on x and y axis. Went with a regular all thread for the z axis. Steppers are mounted and coupled. Build the stand and set the router in the mounts. Working feverishly on the electronics. I want to see this baby move! Couple of pics with the router. Should have some pics of the electronics tomorrow.
  1. pulling bar without barpuller
    By pit202 in forum Haas Lathes
    Last Post: 06-02-2008, 06:32 AM
  2. 203V Pulling my hair out!!
    By WilliamD in forum Gecko Drives
    Last Post: 04-18-2008, 07:09 AM
  3. Pulling force meter
    By Green Button in forum Uncategorised MetalWorking Machines
    Last Post: 09-26-2006, 07:36 PM
  4. Mazak QT-10 Bar Pulling
    By jbhill in forum DNC Problems and Solutions
    Last Post: 08-09-2004, 01:16 PM
  5. Is Taig pulling my leg?
    By c131fr in forum Taig Mills / Lathes
    Last Post: 07-12-2004, 10:31 AM
