586,655 active members*
3,624 visitors online*
Results 1 to 13 of 13
    Jan 2007
    56
    G71 for Stock Removal
    Hello. I have a leadwell LTC-15 with a Fanuc-OT controller. I have used G71 for roughing and G70 to finish in the past, and it has worked well. Now, I am trying to do the same thing, using G71 for Stock Removal in Turning. I enter all of my G-codes, and everytime it begins the cycle, it feeds down to the final cut of the rough ( .01 on Dia, and .005 on faces still remains ) immediately, instead of doing the usual Linear cut. Here is my Code :
    G01 Z0.1 X3.8
    G71 U0.02 R0.1
    G71 P1 Q2 U0.01 W0.005 F0.008
    N1 G01
    X1.15
    G03 X1.25 Z-0.05 R0.05
    G01 Z-.425
    G02 X1.35 Z-.475 R0.05
    G01 X2.90
    G03 X3.0 Z-0.525 R0.05
    N2 G01 Z-1.41
    Thanks for the help, I hope I can figure this out...
    Mar 2008
    638
    Isn't there suposed to be a rapid move between the N1 line and the first feed?
    Like maybe:
    G01 Z0.1 X3.8
    G71 U0.02 R0.1
    N1 G0 X1.15
    G1 Z0
    G01 Z-.425
    G01 X2.90
    N2 G01 Z-1.41
    It's been a couple of years so I may be way off.
    Feb 2006
    992
    Quote Originally Posted by stuby View Post
    G01 Z0.1 X3.8
    G71 U0.02 R0.1
    N1 G01
    X1.15
    G01 Z-.425
    G01 X2.90
    N2 G01 Z-1.41
    Try this somehow your program doesn't work right. I think because N1 mess up.
    G00 Z0.1 X3.8
    G71 U0.02 R0.1
    N1 G0X1.15
    G01Z0
    G01 Z-.425
    G01 X2.90
    N2 G01 Z-1.41
    The best way to learn is trial error.
    2932
    It's my understanding that N2 should be an X move back to the starting X. It's never failed when I've done it that way.
    G01 Z0.1 X3.8
    G71 U0.02 R0.1
    N1 G0 X1.15
    G1 Z0
    G01 Z-.425
    G01 X2.90
    G01 Z-1.41
    N2 G00 X3.8
    Nov 2004
    110
    Here is how I would do it.
    G0 X3.8 Z.1
    G71 U0.02 R0.1
    N1G0X1.15
    G01Z0F.002
    G01 Z-.425
    G01 X2.90
    G1 Z-1.41
    X3.8F.01
    N2G0Z.1
    G70P1Q2
    Push the green button
    May 2007
    1003
    G01 Z0.1 X3.8
    G71 U0.02 R0.1
    N1 G01
    X1.15
    G01 Z-.425
    G01 X2.90
    N2 G01 Z-1.41
    N1 needs to have an X value. Out of about 25 lathes in our shop that can use this cycle, all but one will run with a G1 in the first block. That one lathe has to have a G0. Probably a parameter. Otherwise your program is fine...with one exception. Why are you retracting so far? My standard is R.01. You're wasting a lot of time cutting air.
    You do not need to finish the cycle with an X3.8 unless you want the shoulder to be smooth. I personally wouldn't use a G0 if you did want to.
    Using a G0Z.1 in the last block is redundant as the canned cycle will automatically rapid to X3.8Z.1 after it finishes.
    What are you machining that the DOCs are so small?
    Nov 2004
    110
    Quote Originally Posted by g-codeguy View Post
    Hey g-codeguy.
    I realize that goz.1 in the qnline is redundant.......
    The onley reason I do it is because the guy that tought me on a Hardinge conquest T42 is because he said that not all can cycles on all machines act the same and it is best just to be safe?
    My guess is that that you have never seen a machine that did not retract in the can cycle?
    So do you always end your QNline with the stock diameter in x?
    adamant
    Jun 2008
    5
    iv worked on a ltc 15, im in work tomoro morning ive got all the g codes still.
    i think of the top of my head its on one line
    G71P10Q20U.01W.002D200F.004
    Note D this is your depth of cut.
    then G70P10Q2O for finishing cut.
    ill check tomoro at work.
    May 2007
    1003
    Quote Originally Posted by adamant View Post
    Hey g-codeguy.
    adamant
    Nope. Never ran a lathe in 23 years that didn't return to the canned cycle's starting position. That includes an Ikegai, and some Warner & Swaseys that were undoubtedly older than that when I started. Doesn't mean that there couldn't be some out there that don't, tho. I'm only familiar with Hardinge, Mori Seiki, Daewoo, Takisawa, Nakamura-Tome, Hitachi Seiki, Okuma, Yang, CMS, & some converted manual Hardinges with Fagor controls. Lot more brands out there.
    As to ending the cycle at stock diameter...sometimes yes, sometimes no. Depends on where the cycle is ending.
    BTW, I was only trying to point out that the Z.1 was unnecessary (to the best of my knowledge), not trying to take a dig at you. Or anyone else for that matter.
    I try to keep my programs as clean as possible with no extraneous code. Naturally I ass-u-me that everyone else does also. Tain't necessarily true. Witness some programs with a G1 or G0 on almost every line. Now I suppose you are going to tell me that some lathes require it. You could be right.
    Jan 2004
    185
    ac123 has the answer you missed out the D for depth of cut on each pass
    BR
    May 2007
    1003
    Quote Originally Posted by bbrreid View Post
    Never seen a G71 two block call that used a D code. The U.02 in the first G71 block is the depth of cut for each roughing pass.
    A single block G71 call is something else.
    May 2005
    11
    Hi Stuby,
    code looks fine to me, are you sure you've not got another N1 or N2 line number any where in programme.
    Regards
    May 2007
    1003
    G01 Z0.1 X3.8
    G71 U0.02 R0.1
    N1 G01
    X1.15
    G01 Z-.425
    G01 X2.90
    N2 G01 Z-1.41
    Apologize for not paying attenion to the actual values in your program. You are starting at Z.1 and then swinging this radius, G03 X1.25 Z-0.05 R0.05
    It will run on most machines I am familiar with, but I'm sure you can see that it wouldn't give you the desired result. Course this has nothing to do with it feeding down to the final cut.
    Did you ever get this cycle working correctly?
  1. Type II G71 Stock Removal on Fanuc 0i-TB
    By lowehardware in forum G-Code Programing
    Last Post: 05-06-2008, 02:50 AM
  2. Type II G71 Stock Removal on Fanuc 0i-TB
    Last Post: 01-09-2008, 12:55 AM
  3. fast stock removal on steel
    By dynamotive in forum MetalWork Discussion
    Last Post: 02-02-2007, 04:02 AM
  4. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
  5. Fanuc 0T Stock Removal Cycles
    By M@T in forum Uncategorised CAM Discussion
    Last Post: 11-02-2003, 01:43 AM
