586,119 active members*
3,465 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Microstepping driver too easy.
Results 1 to 20 of 20
    Jul 2003
    246
    Making unipolar microstepper driver now too simple.
    What you want? How much amper, how much volts ? Which microstep number?
    Don't worry by MCR1207 hybrid.
    1) Design step.
    Load the MCR.exe and run it.
    This program want some informations about your stepper motor.
    Program draw the driver schematics for given motor parameters and give component list If you fill the blank data area.
    2) Building step.
    Build the given schematics by given component list.
    3) Configuration step.
    Connect the dir, enb, err and Gnd pins to RS232 port of your computer, apply the hybrid voltages and rerun the MCR.exe
    4) Last step.
    Press to program button.
    Now your motor has ideal driver. Because driver and motor matched.
    com/Programlar/MCR.exe
    32 microstep low rpm demo film
    4 microstep high rpm demo film
    MCR1207 read motor currents and calculates pwm value with digital signal processsor in the real time.
    MCR1207 electronic hybrid circuit coming soon.
    Price? Surprise.
    Jul 2003
    246
    Pcbs finished.
    Now I am looking cheap coating material for the hybrid circuit.
    Jul 2003
    246
    First two cards completed but now i have big problem.
    I don't know how I can coat this circuit.
    Any idea?
    Aug 2006
    2758
    Quote Originally Posted by bunalmis View Post
    Any idea?
    Hello;
    Try http://www.masterbond.com/produse/produse_pe.html . I will continue searching for other options.
    Best regards,
    Kreutz.
    Aug 2006
    2758
    Jul 2003
    246
    Thank you Kreutz,
    But I can not find this products in my country.
    Aug 2006
    2758
    Material Property Considerations
    1. Cured Epoxy Coefficient of Linear Expansion (CTE) match to Solder Joint interconnects, Sn63Pb37 (21ppm/°C) - Pb95Sn5 (29ppm/°C), 65% to 70% silica filler.
    2. High Glass Transition (Tg) to achieve all product storage life temperature requirements (Minimum Cured Epoxy Tg ≥ Substrate Tg; FR4 = 120°C to 135°C, BT/Enhanced FR4 = 170°C to 185°C).
    3. High adhesion properties to BCB passivation and to LPI solder masks.
    4. Low Ionics < 100ppm total Halides.
    5. Low Viscosity and Fast Flow rate, with flow capability to 50mm (2mil) minimum gap size.
    6. Low warpage, low shrinkage matrix.
    7. Minimal moisture absorption.
    Aug 2006
    2758
    Thank you Kreutz,
    Hello;
    It is not the same encapsulating individual components (resistors and capacitors) as encapsulating a PCB + solder + soldermask + already encapsulated components, the encapsulation/potting process and materials are different.
    Why don't you sell the boards without encapsulation? Whoever could reverse engineer your boards could also design them themselves.
    Regards,
    Kreutz.
    Jul 2003
    246
    I want same as hybrid type product.
    Professional seem importand for me.
    Like this
    Aug 2006
    2758
    Info: http://www.chipscalereview.com/9803/wong2.htm
    Material: http://www.sanyu-rec.jp/e-denzai/den06.html
    Jul 2003
    246
    Three MCR1207 hybrids working on the pcb router.
    Microstep mode: 10
    Current set 1.5A
    Video link http://www.bikomak.com/Avi/Pcb_Cnc.wmv
    Aug 2006
    2758
    Congratulations!.
    Did you ever get the encapsulation done?
    Best regards,
    Kreutz.
    Jul 2003
    246
    Thanks.
    Not yet. But i tried 3 card.
    I used cellulosic varnish but I dont liked.
    Use aluminum oxide filler epoxy. It is heat-conductive and extremely abrasive in case someone wants to scrape it away to see what's inside.:-)
    Mariss
    Apr 2007
    1955
    Hi - I don't want to make this a commercial hype here or anything, but if anyone needs help with the sanyu-rec products, I rep for them in North America. Just send me a pm.
    There are quite a large number of good conformal coating materials on the market from many suppliers.
    Aug 2006
    2758
    Quote Originally Posted by harryn View Post
    Good to know, I will be contacting you in the near future.
    Best regards,
    Kreutz.
    Jan 2009
    25
    Microstep mode: 10
    Current set 1.5A
    Bunalmis,
    Could you post the schemantic of this driver? and then everybody have chance to learn.
    Jul 2003
    246
    I add the driver schematics and two video link. But firefox cant open these video. (Before opening save these file)
    Video1
    Video2
    Jan 2009
    25
    Video1
    Video2
    Bunalmis,
    Thanks for your schematic. Main tasks are take care by MCR1207. How much for one set MCR1207? When and where we can buy it?
    Jul 2003
    246
    Hybrids not tested for very hard conditions. (100v 10A driver).
    Normaly hybrid functions independent from driver voltage and motor current.
    But i must give sample large power driver schematics for designer.
    Price not determinated.
    I am working on Cnc pcb machine (you see at the video) and my all time finish.
  1. Linistepper - cheap unipolar microstepping driver
    By lietuvys in forum Open Source Controller Boards
    Last Post: 10-04-2014, 08:13 PM
  2. TB6560HQ microstepping stepper driver chip
    By lucas in forum Stepper Motors / Drives
    Last Post: 01-18-2010, 10:26 PM
  3. A circuit board for the SLA7062M microstepping driver
    By Edison4 in forum News Announcements
    Last Post: 05-04-2008, 09:59 PM
  4. supply microstepping driver
    By claudia in forum News Announcements
    Last Post: 01-16-2007, 09:26 AM
  5. NEW Arcsin microstepping motor driver
    By cnc2k in forum Stepper Motors / Drives
    Last Post: 04-30-2005, 04:13 AM
