586,094 active members*
4,248 visitors online*
    Aug 2007
    13
    cutting expanded metal
    just wondering if anyone in DT land has cut some expanded metal or perforated metal and what kind of settings you used.........ken
    Jul 2007
    54
    Quote Originally Posted by KjZitur View Post
    i'd give call down to dynatorch and see if they can steer you in the right direction..
    Aug 2007
    13
    Yea, I thought of that , but I figured I ask around here first...thanks anyway.....
    Feb 2007
    22
    I cut perf. all the time. I just use about the same settings that I use for the same gauge solid. I cut 22 to 16 Ga. perf. with no problems stainless and galv. I still use the THC.
  1. cutting thin metal
    By clittle in forum MetalWork Discussion
    Last Post: 09-05-2007, 10:27 PM
  2. Cutting metal
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 02-20-2005, 06:14 AM
  3. Q for metal cutting with table saw
    By cnc2k in forum MetalWork Discussion
    Last Post: 02-10-2005, 01:41 AM
  4. help with metal work cutting
    By berin in forum Material Machining Solutions
    Last Post: 08-17-2004, 02:07 AM
  5. Best tool for cutting metal?
    By PsyKotyk in forum MetalWork Discussion
    Last Post: 04-01-2004, 09:10 AM
