586,441 active members*
6,451 visitors online*
IndustryArena Forum > MetalWorking > Welding Brazing Soldering Sealing > change inch welding measures to metric
    Apr 2008
    5
    We have a problem and we need fast answer.
    If i have a inch dimension picture where is weldin symbol 1/2 at one side of the part what it mean when i convert it for metric system ?
    Edit: add dxf picture what i mean.
    Attached Files Attached Files
    Mar 2008
    Just convert the weld size to the metric equivalent by dividing by 25.4. The weld will remain a fillet weld. the 1/2" should become 12.7mm or 12mm depending on your precisioin.
    Apr 2008
    5
    Thank you.
    Mar 2006
    ACAD
    BTW you can do this in ACAD no problems in less than a couple of minutes.
  1. Metric to inch conversion
    By BobF in forum Mach Software (ArtSoft software)
    Last Post: 12-28-2007, 05:53 PM
  2. inch metric alarm
    By bigbobr in forum Fanuc
    Last Post: 11-15-2007, 07:40 PM
  3. DRO - Metric or Inch
    By DJ Morrow in forum CNC Machine Related Electronics
    Last Post: 11-15-2004, 09:06 PM
  4. Metric vs Inch - arguements pro & con
    By DJ Morrow in forum Mini Lathe
    Last Post: 08-12-2004, 02:46 PM
