587,070 active members*
3,038 visitors online*
    Sep 2006
    251
    no spindle reverse?
    I have a 1996 Mazak QT-20 with a T-Plus controller and can't get the spindle to cut in reverse mode. It has Mitzubishi controls and the NC # is 515LWY40X6. The Mazak Serial Number of the machine is 126067. My operator and I have tried a few things with no luck. It will turn in reverse when you push the reverse rotation fast key on the contoller, but we can't seem to get it in an auto program or an MDI program. We have gone into the tool data page and changed the rotation arrow, but it still runs in the forward direction. Are there parameters that may need changed for this to turn properly? Any help is greatly appreciated. Thanks in advance!!
    Just a good ol' boy, never meanin' no harm.
    Joe
    Jan 2008
    24
    are you using G and M code or the Mazatrol programming and what have you tried so far?
    JM
    Sep 2006
    251
    Still no reverse.
    Quote Originally Posted by 337MPH View Post
    JM
    337,
    We have checked the parameters with other machines. We have tried to right a program with g-code format. I am the maintenace guy, and my programmer/operator says that this is the only machine out of 22 that will not reverse the spindle rotation. Again, he has tried to change the arrow in the setup mode and also tried G & M codes. It does run in reverse when not in auto mode, using the quick key on the panel, but this doesn't help for automatic cycles. He has programmed it for forward and reverse rotation with M Codes, but in auto, it always turns forward. Still looking for answers.
    Thanks for the reply.
    Joe
    Feb 2006
    992
    Quote Originally Posted by JoBwan View Post
    Try with run M code in MNP and see if it work..... if it does then call your dealer ask for parameter....
    The best way to learn is trial error.
    Sep 2006
    251
    No Reverse.
    Quote Originally Posted by newtexas2006 View Post
    Hey Tex,:
    I opologize for being ignorant on this, but I dont understand what you mean by "Try run with m-code in mnp"? What is mnp?? Could you give me a sample program that should work? My Mazak knowledge is pretty limited.
    Joe
  1. Can't reverse spindle
    By protrxrptr17 in forum G-Code Programing
    Last Post: 04-18-2008, 07:26 PM
  2. Spindle Reverse on a Bridgeport Interact?
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2007, 02:04 PM
  3. Spindle Forward/Reverse = High/Low change
    By AdyAstley in forum Machines running Mach Software
    Last Post: 06-07-2007, 03:33 AM
  4. reverse spindle problem
    By bala955 in forum Fanuc
    Last Post: 03-09-2007, 12:24 AM
  5. Spindle sticking in reverse
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 10-02-2006, 04:48 PM
