586,106 active members*
3,012 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 4 degree angle axis for toolpath?
Results 1 to 8 of 8
    May 2007
    327
    Is there a way to tilt the working axis? I need a 4 degree cut on the end of a part. Don't see a way to tilt the x/y/z orientation.
    thanks R
    Rich,
    Are you talking about tilting the part to cut a certian area? if so use xform rotate.
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    May 2007
    327
    does that change the toolpath / working plane ? I don't want to tilt the part, just that one toolpath needs to be on a plane with 4 degree angle.
    you can define a 4 deg plane fror that toolpath in wcs
    this link may help watch this video
    http://www.cad2cam.net/zany.html
    steve
    www.cad2cam.net
    www.cad2cam.net
    May 2007
    327
    nice video thanks, very helpful
    side note, still have not found a way to make a plane at an angle so imported some geometry that had those features.
    Rich,
    the quickest way I found is to draw a circle and rotate it about the center by 4 degrees. you can pick that as a plane ( note when you rotate you may want to set your construction(working) plane to front or side to use this) Of course using existing Geometry is fine too.
    steve
    www.cad2cam.net
    www.cad2cam.net
    Apr 2003
    3578
    Have you tried contour. review pictures.
    Cadcam
    I don't think he was doing this but maybe if so sorry this is a easy way to do a taper 4 degree.
    www.cad2cam.net
  1. toolpath using rotary axis
    By dpark1 in forum Mastercam
    Last Post: 09-04-2007, 12:42 PM
  2. 4-5 axis milling toolpath
    By aldebaran07 in forum Mastercam
    Last Post: 05-21-2007, 02:42 PM
  3. 4th Axis Toolpath with mastercam
    By rcrabb in forum DIY CNC Router Table Machines
    Last Post: 01-07-2007, 03:41 AM
  4. 45 degree bevel on angle iron
    By Rypper in forum DIY CNC Router Table Machines
    Last Post: 11-14-2006, 07:00 AM
  5. Full 4 axis toolpath generation?
    By Konstantin in forum Rhino 3D
    Last Post: 11-12-2006, 07:14 PM
