586,704 active members*
2,595 visitors online*
    Nov 2004
    17
    About Chinese 100W Laser Engraver
    Hi everybody;
    I'm thinking of buying an 100W chinese laser engraver, but i am curios about if i will be able to cut 20mm acrylic with this machine or not? and how speed i can cut?
    Thanks now...
    Feb 2008
    66
    i could cut 1 cm acrylic with 80watt laser by one pass.
    i use speed 1.5 power 95
    maybe if want to cut 2 cm, i could use two pass.
    Dec 2006
    48
    with lasers-edge 60W machine, you can cut acrylic as deep as 3/4" and 1" on 80W,
    frank
    Sep 2008
    I cut 25 mm clear acrylic by one pass.
    I use speed 5cm/min and power 80%
    Laser mashine JHF Vista LE1200 80W
    Dec 2007
    13
    I cut 10 mm acrylic
    2 mm/s 65 % power of 80W laser
    higher power of cutting can increase speed, but not very much.
    I cut 20mm acrylic by two pass.If you want to obtain good quality of edge,the cutting can not be too fast.
    If you want to cut acrylic more then 10 mm,the power is not so necessary as a time.
    Maybe power more then 200 W can make it very quickly,who knows...
    Grzegorz
    WK Laser LC1280 80W
  1. Add US made laser module to Chinese laser?
    By glintid in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-02-2012, 08:43 AM
  2. Where to buy a Chinese 80W Laser
    By PaioX in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-17-2010, 08:57 AM
  3. about chinese laser cutters
    By buddhafragt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-04-2008, 11:00 AM
  4. Chinese Laser
    By FMA1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-19-2008, 12:38 PM
  5. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
