586,103 active members*
3,300 visitors online*
    Dec 2007
    61
    Camsoft Pro basic features
    Have the basic features changed on the latest version of Camsoft Pro from previous such as Ver.15? Do you still have to go up levels to get features like roughing and simulate?
    Mar 2004
    1543
    I've got Pro level 1. I don't use the CAM package at all so i can't comment there. The control part has had numerous minor improvements but its the same basic package. I'm sure I would have heard if simulate was added to level 1.
    Karl
    Apr 2003
    332
    Bob,
    V15 and V16 are the same in this respect. They include both solid model and wire frame 3D simulation and basic lathe and pocket roughing canned cycles. If you're thinking of our CAD/CAM product Advanced System 3000 it does require an upgrade from Level-1 to Level-5 to get full mill/lathe roughing and a higher end solids graphic simulator than what the CNC Controller gives you. This has much more control over the simulation process such as light sources, part slicing, dimension measuring and cutter animation super imposed on imported STL files.
    Tech Support
    CamSoft Corp.
    951-674-8100
    [email protected]
  1. What features would you like to see?
    By cncadmin in forum SheetCam
    Last Post: 06-12-2011, 03:06 PM
  2. Adding features
    By bdrmachine in forum Solidworks
    Last Post: 01-14-2008, 02:39 PM
  3. new features
    By single phase in forum Hypermill
    Last Post: 11-21-2006, 06:31 PM
  4. EdgeCAM Features
    By jb1knobe in forum EdgeCam
    Last Post: 04-13-2006, 08:34 PM
  5. Does OneCNC have these features?
    By Dan B in forum OneCNC
    Last Post: 01-27-2006, 06:38 PM
