586,537 active members*
2,922 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > I need IGF manual or pdf for okuma LB15
    Jun 2008
    I need help using okuma IGF programming on a osp5000 G-L LB15
    I need to write a small program for a second operation.
    Face to over all length and match bore ID and chamfer at end of part.
    process 1 Rough face over all length
    process 2 Finish face O A L
    process 3 Rough bore I D
    Process 4 Finish bore I D with 45 chamfer @ face or start point
    Oct 2012
    hi need help want okuma LT15 OSP 7000L program manual,plz
    Oct 2012
    Process one rgh face part down Ref pt x = raw od size+.100 z= amount to b faced off to get oal
    St pt x = raw material size z= 0
    End pt x= 0 ( or if a hole is n the part go .100 below the hole size)
    Note: b sure to leave stock in z to finish face an nothing n x i usually run this at about .05 depth of cut .008 feed and 450 depends on material and how far its stickin out
    Oct 2012
    Process 2 fnh face create process 2 input all info rough copy process 1 and make sure stock left is 0
    Process 3 rgh id< ref pt x =Drill hole size z=.100
    Start with a taper it will make more sense to u when u start cuttin diff angles then 45's
    Taper/ st pt x=finished id size + double chf size (ex id bore is 2.0 an they want 45x.060 so its 2.0+..120) z=0
    End pt x= finish bore size (from ex^ 2.0)
    Z end pt leave blank
    Z angle 180+45 ( i it was a 60dgr comin off the 180 plane it would b 180+60 this only on the id if u were on the od it would b a 180-45 etc only if it the angle comes off 180 plane)
    The lOng< z end pt how ever far u need to go
    Leave stock in z and x
  1. okuma LB15
    By NJC in forum Okuma
    Last Post: 04-11-2013, 05:40 AM
  2. okuma lb15 spindle drive unit
    By TTT in forum Okuma
    Last Post: 02-03-2011, 03:49 PM
  3. parts catcher in my Okuma LB15
    By mikul in forum G-Code Programing
    Last Post: 04-22-2008, 07:49 PM
  4. Okuma LB15 - osp5000L software
    By daikatana_ in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-22-2008, 01:22 PM
