586,061 active members*
4,576 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Refractometer Value ? Kool Mist #77
    May 2007
    327
    3200 RPM using Kool Mist #77 40:1 ratio, as flood coolant 11 gallon per minute steel and aluminum cutting.
    I got a $35 refractometer off ebay. Calibrated it to 0 with distilled water. Right now my flood coolant is reading 2.5 1-30 scale 20 celesus. Most of my tramp oil has been skimmed by a belt.
    Is this a correct reading. Can find nothing on what factor Kool Mist used as flood would be. I dont need perfect just a decent number.
    Thanks! . R.
    May 2007
    327
    seems I am a bit high here is the recomendations from Kool Mist chemist.
    might explain why i have not a spec of rust..
  1. refractometer
    By fourperf in forum Haas Mills
    Last Post: 01-11-2008, 05:48 PM
  2. Spra-Kool midget intermittant spray mod
    By pdxalz in forum Benchtop Machines
    Last Post: 11-10-2007, 09:43 AM
  3. Found a kool link for lathe newbies
    By ZipSnipe in forum Mini Lathe
    Last Post: 03-19-2006, 05:26 PM
  4. Kool Mist coolant, opinions
    By phantomcow2 in forum Uncategorised MetalWorking Machines
    Last Post: 11-11-2005, 01:18 AM
  5. Kool
    By CAMmando in forum Musical Instrument Design and Construction
    Last Post: 07-08-2003, 08:20 PM
