At first I thought the house was haunted, but I'd be very grateful for help analysing the following problem.
First, about 6 weeks ago, we went on an economy drive after the last electricity bill. Using a plug in metered socket, I discovered the workshop monitor/pc which I thought switched off when I hit the off button, was still drawing about 0.3 amps, 24/7. So I switched it off at the mains as well.
Then we noticed the electric blanket(the bedroom sockets are through the wall to the workroom sockets) didn't work properly, after 8 months with no problems. Most of the time the neon(?) dial illuminator was flickering, and the blanket might or might not get warm. Appeared to be random.
So that went back to the supplier and exchanged for a new one.
That seemed OK for about 4 days, then stopped working. The power neon was on, but no heat developed.
(It has an electronic timer/controller.)
Then we noticed the clock/radio in the bedroom was playing up, with either the dro flickering or the clock minute indicator cycling every 5 seconds.
Haunted house?
I've tracked it down so far to the fact that if the monitor is switched on at the socket and on standby, the clock/radio and the electric blanket work normally.
The same is true wherever the clock is taken to in the house.
Nothing else plugged into the socket has the same effect as the monitor.
I've tried surge protected strip sockets as well, but nothing alters the effect of the monitor.
When it's on standby, the clock and blanket work. When it's switched off, they don't.
Haunted monitor ? In use with the PC it appears to work completely normally.
Any ideas ?
It would be some help if I new what type of load the monitor is presenting when on standby, so that I might emulate the load to see if that's the root of the problem.
John
