586,103 active members*
3,805 visitors online*
Results 1 to 8 of 8
    Mar 2008
    638
    Sample EIA program for Mazak lathe
    Hi everybody,
    Well, I tried to get information on variable lead threading using Mazatrol. I received no answers so I figure it can't be done. I also called Mazak application support and he had never heard of it being done with Mazatrol but couldn't rule it out. He suggested EIA (which we have as an option but have never used). Now I'm fairly new to Mazak but I've programmed for years on Okuma, Nakamura, and Star lathes in previous jobs. My experience with those (all using G codes only) says that our Mazak is going to want a specific layout. I'm talking about the start of the program, calling up tools, and ending the program. I can figure out the variable thread but I really don't want to crash the machine by leaving something out that it wanted.
    Long story just to ask:
    Can somebody post a sample EIA program for a Nexus 100 lathe with a 640T controller?
    Chris
    Apr 2008
    44
    why u need EIA program for mazak,for me mazatrol program is the best program for turning
    all shape can make in mazatrol & mazatrol is very simple & easy
    so i think EIA program not required
    Apr 2008
    49
    Mazak EIA is verymuch same as Fanuc format,
    if you still need sample of the EIA here it is
    (Program using tool#6)
    G20
    G28U0.W0.
    (your text )
    G0T0606
    G97S1650M03
    G0X1.0Z1.0M8
    G99G1Z-3.6151 X1.3091F.1
    G1Z-3.6651F.007
    M9
    G0 Z.5
    G28U0.W0.
    T0600
    (END OF FILE)
    M30
    Mar 2008
    638
    Thank you for your replys. I got a sample program from Turkay Geyik two weeks ago and it gave me the confidence to see that it wasn't any different from the basic format I was used to. Transfering it by floppy took a while to figure out what it needed.
    Mazman- I needed it for the variable lead thread. Do you have a way to do it in Mazatrol (which I like as well)? I did run the variable lead thread in EIA and it worked. Or at least it didn't alarm- I was doing it to verify that we could do it if needed but didn't turn actual metal. We'll see if it's needed later.
    Thanks guru for posting the sample.
    Aug 2011
    hi i have 6+ years experiance in mazak so you can ask me i will ready to explain what you need.
    Sep 2010
    i need an eia sample program for a mazak 200m with c axis
    Sep 2010
    do you have a sample code were you use cutter comp for a live tool on a Mazak lathe
    Mar 2008
    638
    I don't but maybe someone who answered my post will. Good luck.
  1. Sample 4th axis Program please....
    By bullseye in forum Mach Mill
    Last Post: 06-02-2010, 10:42 PM
  2. Mazak M2 Sample program EIA
    By zabba in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-01-2008, 12:23 PM
  3. Plotting a sample program.
    By rsm169 in forum NCPlot G-Code editor / backplotter
    Last Post: 03-17-2008, 01:36 AM
  4. Post a sample of the program.
    By Mitsui Seiki in forum G-Code Programing
    Last Post: 02-03-2008, 04:18 PM
  5. Need IEI-ISO sample program for Mazatrol 640 T
    By turkaygeyik in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-29-2007, 03:03 PM
