586,106 active members*
3,040 visitors online*
Results 1 to 2 of 2
    Aug 2007
    17
    Dyna 4500 Tool Changer Issues
    I have a DM4500 Dynamechtronics Mill with a Mitsubishi M3 control. My tool changer is not working in Memory mode. Could someone please post their tool changer macro from their DM4500?
    Also, if anyone has any ideas... my tool changer will work perfectly when the macro is set as a type 2 and it is run in MDI mode. However, when in memory mode it hangs before the Z axis moves up to remove the tool from the spindle. The alarm it gives is M01 0004 Z which is a Z axis external interlock. It does this when set as any type in Memory mode and as 0, 1, and 3 types in MDI, but type 2 MDI mode works fine.
    Any ideas?
    Mike
    Aug 2007
    17
    any ideas?
  1. Excel Tool Changer Issues
    By Rustrap in forum Uncategorised MetalWorking Machines
    Last Post: 11-15-2007, 10:37 PM
  2. Dyna Mite 4500M Tool Changer Program
    By jetblackaircraf in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-17-2007, 02:54 AM
  3. Dyna Myte 4500 Driver
    By GEO:s Motor in forum Engraving Machines
    Last Post: 04-27-2007, 08:30 PM
  4. Dyna Myte 4500 Driver
    Last Post: 04-27-2007, 08:26 PM
  5. Dyna Myte 4500 Driver
    By GEO:s Motor in forum G-Code Programing
    Last Post: 04-27-2007, 08:13 PM
