586,113 active members*
3,211 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Drill Rod Diameter Recommendations
Results 1 to 7 of 7
    Apr 2004
    8
    I am building a fixed gantry CNC foam-cutting mill. It will only be cutting foam.
    Usable "X" is 30 inches, so drill rod length will be 60 inches.
    What is the recommended diameter for the drill rod in this application?
    Thank you.
    Rgds,
    G. R.
    6855
    The bigger the dia the better on 60" I'm thinking 1/2-3/4" dia.
    Jun 2003
    3312
    where are you going to get 60" long drill rod?
    Phil
    May 2003
    550
    A drill rod in 60" will be hard to find.
    IS that 60" one rod? and how is that supported? How accurate do you want this to be? What sort of weight will they carry?
    FYI
    A 60" 1/2" drill rod 'fixed' mounting at either end with a 10lb load at 30" will deflect ~0.13"
    A 60" 3/4 drill rod 'fixed' mounting at either end with a 10lb load at 30" will deflect ~0.026"
    For simple support at both ends those figures become 1/2" = ~0.52" deflection, 3/4" ~0.1" deflection.
    For a *really* rough estimate within a small margin if you double the weight the deflection would double too.
    note for a home built machine the actual rigidity of end supports would be somewhere between 'fixed' and 'simple'. 'Fixed' meaning absolutely no movement, not feasible unless the machine is really massive. The much used idea of adjustment blocks with four bolts around the shaft would be more or less equivalent to a 'simple' support.
    Apr 2004
    8
    Drill Rod Source
    Thanks for the suggestions.
    As to the source of drill rod, how about
    http://www.crucibleservice.com/esele.../drillrod.html
    As you can see, they have it in 3 foot and 12 foot lengths. Am I missing something here or is there really no problem about sources?
    Once again, thanks a lot.
    Rgds,
    G.R.
    Oct 2004
    85
    Use 3/4 rod with open style bearing and support the entire length.Thats what I did and it seems to work fine.Fixed gantry is the way to go because you can make it more rigid.Good luck!
    4826
    I'd recommend chrome plated shafting for rails. There's nothing special about drill rod in the annealed state (which it is when puchased). Chrome plate is much harder, so long as you treat it nice without nicking it. Friction is also much reduced.
  1. Removal of the drill press depth stop threaded rod
    By devinchi in forum Shopmaster/Shoptask
    Last Post: 03-14-2010, 03:10 PM
  2. Drill Rod For Linear Ways
    By heilcnc in forum Uncategorised MetalWorking Machines
    Last Post: 02-28-2005, 06:41 PM
  3. Drilling a perpendicular hole in drill rod material
    By ngr1 in forum MetalWork Discussion
    Last Post: 12-04-2004, 04:16 PM
  4. drill rod longer than 36"? where?
    By CNC Darren in forum DIY CNC Router Table Machines
    Last Post: 09-26-2004, 02:17 AM
  5. Thomson vs. ground drill rod
    By TommyB in forum DIY CNC Router Table Machines
    Last Post: 03-21-2004, 05:08 PM
