Check all crimps.
Check all crimps to stepper motors.
The plugs (at least the ones on mine) cant be inspected without removing the pins with a pin removing tool turned from a piece of brass.
That's a tube that just fits over the pin and slides into the nylon housing to release the barb. If in doubt give a yank on each wire. If it comes out it was going to cause problems anyway.
ALL CRIMPS on my factory machine were done with the WRONG TOOL.
Also the crimps on the limit switch connectors can have problems.
Ensure ALL screw connections are tight, especially on bootlace ferrules.
A goods idea to undo these, and squeeze with pliers.
Check for tightness and add a dab of loktite or super glue to the nuts holding the stepper drivers in place. A nut fell off mine and killed the switch mode supply. Thank you Syil for prompt replacement.
Intermittent shorts around the display area can kill the electronics.
