586,094 active members*
4,177 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Not plunge into stock material
Results 1 to 6 of 6
    Dec 2005
    436
    I would like to forcM mastercam X2 to Z plunge down in air then move in the XY plane into the stock material or part.
    As of right now I plunge in the Z direction and am forcing my machine to work too hard.
    I tried the "use the approximate start point" option but no success.
    Try checking the "plunge outside containment boundry" option. Your cutter will plunge outside the stock about 1" away from it. No way to change this ridiculously too far distance that I know of but at least it wont be plunging into the material. Which is one of MC's most annoying promlems. Plunging into the stock when you least expect it. It will take you 30 minutes of watching the verification at a slow speed to catch the bogus plunge too. So productive and intelligent are these tool paths. (nuts)
    Apr 2003
    3578
    cncuser are you using the surface rough pocket as Mike is thinking you are using? Have you tried using the Rough core in the HST surface paths this will keep from plunging if you are doing surface roughing..
    Let me know what path you are for sure using.
    Cadcam
    Jul 2003
    263
    create a start point and select it and in the chain dialog box move the point before the chain
    If you can ENVISION it I can make it
    Dec 2005
    436
    containment boundry
    Quote Originally Posted by Mike Stevenson View Post
    Try checking the "plunge outside containment boundry" option. (nuts)
    Well I used containment boundry. I use "outside" option. I use a value I enter into the value window.
    I'm not sure this is the most efficient method. I'm not sure because I'm so tired of messing around I'm in Zombie mode.
    Mar 2006
    1013
    Containment Boundary set to Outside means it will cut outside the boundary.
    Selecting the Plunge Outside Containment Boundary" depends on the toolpath your using. I would use Surface - Rough - Pocket and on the Rough Parameter Page, you'll find the option we're referring to.
    You wont find this option on Rough - Contour or Rough Parallel.
    That should do what you want.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
  1. Working with stock thickness material.
    By svatchi in forum Work Fixtures / Hold-Down Solutions
    Last Post: 03-29-2008, 02:36 PM
  2. Took the BIG PLUNGE
    By HelicopterJohn in forum Haas Mills
    Last Post: 01-12-2008, 05:39 AM
  3. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
