586,071 active members*
3,897 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Tech installed spindle motor fan backwards (now #9)
    Apr 2005
    1194
    Now we are getting a #9 spindle fault error (line low). At this point should we get the motor cleaned and hope the inverter is still good? The error is intermittent and today we are constantly getting that fault every other part. On top the motor the fan is actually blowing out and sucking coolant mist up through the motor (DOH!!!)
    Apr 2005
    108
    you are making some mistake
    there is no connection bitween the fan motor and spindle fault 9
    the fan has to be installed that is sucking air from outside to the motor
    inside
    problem 9 caused or by the spindle inverter
    or you got problem with the power supply
    Apr 2005
    1194
    Thanks but after talking with tech a dirty spindle motor can cause an inverter fault. In fact a dirty spindle motor can ruin an inverter/spindle drive on a Fadal since their isnt a safeguard against resistance from the motor.
    You are correct on the fan but our fan was installed sucking air through the motor not from the top down like it should have been.
    Apr 2005
    1194
    Welp $553.94 later we have a clean motor with new bearings. We are going to install it this weekend and see what happens (fingers crossed)
  1. Make motor run backwards.
    By TahoeTomahawk in forum Stepper Motors / Drives
    Last Post: 06-22-2008, 04:40 PM
  2. Installed tach on 8x14
    By arekugi in forum Mini Lathe
    Last Post: 02-18-2008, 07:19 AM
  3. Macro B installed?
    By grweldon in forum Fanuc
    Last Post: 07-09-2007, 07:19 PM
  4. Help gettig pure dos installed
    By Hack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-03-2005, 03:26 AM
