586,069 active members*
3,379 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Free Router plans! and Discuss it here.
Page 2 of 20 123412
Results 21 to 40 of 393
  1. #21
    Nov 2004
    138
    Wow nice plans. I think I'm going to try to duplicate it myself.
  2. #22
    Nov 2004
    20
    The Plan..
    Hey! Very well done plans! It's weird.. While wracking my brain trying to figure out how to make cheap, effective slides, I stumbled (by accident) on attaching roller skate bearings to pieces of angle irons, and running them along steel shafting, or better yet, 1/2" metal conduit tucked inside 3/4" PVC pipe, all being supported on bottom by that steel "T" bar,(looks like steel fence posts) on the bed of the mill, or router.
    After downloading your plans, lo and behold! There's "my" idea - I swear I had never seen it before yesterday!! Isn't that weird? But man, It works!! Very cool.. Thank you for your hard work and dedication for making the plans!!
    (here, I'll put in a cheers smiley for ya! :cheers: )
    -Jeff Thorsgaard
  3. #23
    Nov 2004
    8
    Excellent.
    Thanks for your contirbution.
    John
  4. #24
    Jul 2004
    242
    I get an eeror when I click on the link.
    Error Flood Check If you followed a valid link, please notify the webmaster
  5. #25
    Nov 2004
    8
    Sorry, my email address was disabled. I've enabled it now.
    John
  6. #26
    Dec 2004
    17
    Cannot access plan
    Tried to open the .pdf file but got an error message. Any ideas?
  7. #27
    6855
    Just tried it opened up no problem. Make sure you reader is up-to-date.
  8. #28
    Dec 2004
    17
    Cool Still cannot open
    Hello,
    Went to Adobe's web site and downloaded and installed every update I could. Still won't open for me. Any possibility you could e-mail these plans to me? Would really appreciate it.
    [email protected]
  9. #29
    Dec 2004
    17
    Voila!!
    I right clicked the link and did a "Save target as" ....Got it..
    Thanks :cheers:
  10. #30
    Ygm............................................... ..
    Please check out my CNC blog
    http://cncinside.com
  11. #31
    Nov 2004
    138
    Question about the use of gas pipe as bearing rails.
    Should a person have then turned on a lathe to smooth them out or will plain sanding do the trick?
  12. #32
    6855
    I would think that just sanding it with emory paper would be enough.
  13. #33
    Dec 2004
    17
    New to this, please help.
    Have a question, I am a cabinet maker making this machine and am looking for all new electronics for a good price. Now the thing is I have enlarged this to a cutting area of about 36"x60" and will not be using this for cabinets but to cut foam and 1/4 ply wood. So around what 0z. steppers motors ,ECT. do I need. Any help would be greatly appreciated! thanks in advance. Jason
  14. #34
    Sep 2004
    179
    I have an enlarged version also at 16X36 mostly cutting 1/2" MDF and I am running 116 in/oz motors and they seem to work fine using 3/8-16 threaded rod. I had 80oz/in motors and they worked ok too but never went back to them. Watch the whipping of the lead screw mine at 36" gets kinda scary at anything above 70 ipm when joging.
    Darren
  15. #35
    Dec 2004
    17
    16x36" ?? Is that not the close to the size in the plans? Where is a good place to buy these steppers and electronics? Thanks
  16. #36
    Sep 2004
    179
    Pretty much the same size but just extended 12".
    I'm using the HobbyCNC 3axis chopper driver board.
    The 80 oz motors came from HobbyCNC
    the 116 oz/in motors came out of a Sharp Copier, the older copiers used them to feed pages on the document feeder on top of the copier there are 2 in each copier. So far i have managed to get 8 of them. My brother works for a Office machine supply company so he lets me know when they get some junckers in off of lease and we go in and strip them. I have several 38v 15amp that came from copiers that work great for cnc also.
    Darren
  17. #37
    Dec 2004
    783
    Hey Guys,
    Thanks for the Plans!!
    First post, I'm a friend of Ashers helping him out trying to get this thing together. I,ve been looking at a bunch of different programs and motors to use, and i want some opinions.
    Im looking at the 640 oz steppers from homeshopcnc, and was wondering what controller i would need to use on them.
    Also any thoughts about deskcnc and deskam?
    Were planning on using 1/2 inch acme leadscrews(they will fit in the chuck of my lathe) should we go bigger for the long 60" run? or use dual nuts spread out on the gantry to smooth and quiet things down. Any idea of thread pitch to use with the 640 oz steppers? were looking for 120 or so IPM jog rate.
    Ive also been pondering on using timing belts and pulleys between the steppers and screws, is a coarse thread acrew with a geared down stepper better for faster jog and cutting rates, at the expense of a bit of prescision? this way i could also play with gear ratios...
    The machine will mostly be used to cut stacks of 1/4 inch foam....
    Sorry for so many questions, Ive been reading into the late nights on cnczone for a few weeks now, Some of it is starting to make sense.
    Thanks for ANY input..
    Dylan
  18. #38
    Dec 2004
    783
    Not too much activity here...
    Turns out Enco only has 1/2" acme in a 10 TPI, would this work?
    Im pretty sure the Gecko drives will work with the 640oz motors, any thoughts?
    Dylan
  19. #39
    Dec 2004
    48
    I was also thinking about useing 1/2 -10 acme all thread rods and building a teflon nut for the mooving parts. what do you think about this idea?
  20. #40
    Mar 2004
    190
    Dylwad, geckos are OK for any stepper below 80V and 7A. Just remember to heatsink them for currents over 3A.
    /Fer
Page 2 of 20 123412
  1. ---> Free <--- CNC Router Plans.
    By Switcher in forum Community Club House
    Last Post: 02-04-2013, 12:05 PM
  2. 2'x3' Free Router Plans - All Aluminum and Steel, Completely Bolt together
    By LaserImage in forum Open Source CNC Machine Designs
    Last Post: 02-28-2012, 01:28 AM
  3. Completed the ModularCNC Router 2009v1 Free Plans
    By ejjenkins in forum DIY CNC Router Table Machines
    Last Post: 03-24-2010, 06:21 PM
  4. Free Plans for a Router Spindle Mount
    By Modular CNC in forum DIY CNC Router Table Machines
    Last Post: 10-18-2009, 05:34 PM
  5. Free plans Router table Thanks, But help
    By aircub in forum DIY CNC Router Table Machines
    Last Post: 10-16-2005, 08:14 PM
