586,058 active members*
4,306 visitors online*
Results 1 to 6 of 6
    Nov 2007
    5
    Drilling copper
    Hi all, I have just started on cnc zone so here go's.
    I need to drill a .094 or # 41 hole 1'' deep in copper can you get me started on speeds and feeds thanks.
    jerry1122
    Apr 2007
    64
    This is what Chicago Latrobe recommends:
    RPM = 3.82 X SFM / drill diameter
    SFM = 140 - 200
    FR = RPM x IPR
    IPR = .001 - .002
    RPM = Revolutions Per Minute
    SFM = Surface Feed Per Minute
    FR = Feed Rate
    IPR = Inch Per Revolution
    RPM = 3.82 X 140 / .094
    RPM = 5689
    FR = 5689 x .001
    FR = 5.689
    I would use a HSS Tin coated drill.
    You could also call Chicago Latrobe Technical Information 888-434-4311
    Nov 2007
    5
    Drilling copper
    Thank you I am going to give it a try.
    Mar 2006
    489
    Milk as a lubricant apparently gives an excellent surface finish. One of those old trial and error things I read in a book somewhere.
    Paul
    Jun 2008
    130
    I read also about grinding the cutting edge square. It might be worth a search.
    No time to do it right, plenty of time to do it twice.
    Nov 2007
    5
    Drilling copper
    I have it drilling good now 1600 rpm and 30.5 feed.
    I need to run 8,000 per month so will see how it goes.
    Thanks jerry1122
    muskegon mi.
  1. drilling copper
    By jeremyinnys in forum MetalWork Discussion
    Last Post: 08-26-2011, 05:08 AM
  2. copper?
    By bowhunter in forum MetalWork Discussion
    Last Post: 04-26-2007, 06:41 PM
  3. drilling and drilling cycles tutorial
    By wmorre in forum MetalWork Discussion
    Last Post: 10-19-2006, 12:30 AM
  4. milling copper (99%)
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 09-27-2004, 12:34 AM
  5. what tip to use for copper?
    By HawainPand in forum MetalWork Discussion
    Last Post: 09-22-2004, 09:30 AM
