586,060 active members*
4,553 visitors online*
    May 2008
    4
    tool probing issue, probe open ?
    trying to touch off tools using a renishaw touch probe, on our cincy/lamb Hawk 250. A "probe open" alarm is generated when we run the sub to carry out the presetting. Im thinking that the probe "open" is the way that it should be, but an alarm is generated nontheless halting our attempts. Any one else ever encountered this ?
    Apr 2004
    353
    For some reason your probe is being tripped without being touched by a tool. Most likely a damaged cable, causing the wires inside to lose contact. I think the probes are normally closed-loop, and when the probe is touched the contact is broken (open)
    We've had this happed on our machines before, and it has always been a damaged cable somewhere, or a poor electrical connector. Do some investigating and you may find the problem.
    Good louck
  1. Mazak pc fusion probe issue
    By noPROBElem in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-22-2009, 03:01 AM
  2. Tool Probe
    By b.locke in forum HURCO
    Last Post: 02-21-2008, 04:14 AM
  3. Tool Probe Arm
    By phoodieman in forum Daewoo/Doosan
    Last Post: 11-01-2006, 10:32 PM
  4. Tool setting probe
    By JFettig in forum Mach Software (ArtSoft software)
    Last Post: 03-12-2005, 02:33 PM
  5. probe, tool setting
    By bobcor in forum Uncategorised MetalWorking Machines
    Last Post: 03-10-2005, 02:17 PM
