586,565 active members*
3,607 visitors online*
    Jun 2008
    29
    What are these called?
    Hi, I'm in the process of putting together a new "R" or rotational axis for my table. I plan to fire this axis off the supply to the X axis of the table when I use it.
    The stepper motor I'm planning to use is a Pacific Scientific M22 that has an 8 pin straight plug. I want to have a "pigtail" off the motor so I can easily switch back and forth between the X axis and the "R" or rotational axis. Can anyone tell me the 'tradename' or number of this male plug so I don't look completely stupid when I go into Radio Shack or another supply house looking for one?
    It's two separate parts. Amp 641653-8 and 643077-8. You won't find them at RS. Check Digikey or Mouser.
    Jun 2008
    29
    Thanks, If it's going to be that much hassle, I might just solder a cable on to the motor connections and use a more common plug connector on the other end. Got bigger headaches with the software right now. Thanks.
    A quick and dirty fix I have used is to wire wrap 28 or 30 ga. wire on the pins. Works good and there is no solder mess. You can pick up a hand wrap tool for about $20- $30 at Fry's or Digikey or Mouser. Tool # WSU-30 from OK Industries.
    I used to be appalled, now I'm just amused.
  1. What was this Bridgeport called?
    By gtrjunkie in forum Bridgeport / Hardinge Mills
    Last Post: 08-20-2007, 12:21 AM
  2. What is this called and where can I order it?
    By Alex_Cole in forum Benchtop Machines
    Last Post: 01-23-2007, 12:46 PM
  3. What are they called
    By Rhodan in forum Community Club House
    Last Post: 08-23-2006, 06:29 AM
  4. Blind Teeth or so they are called
    By pinguS in forum MetalWork Discussion
    Last Post: 08-02-2006, 08:56 PM
  5. What is the white plastic called?
    By WarrenW in forum Mechanical Calculations/Engineering Design
    Last Post: 12-24-2005, 03:39 PM
